RV042 - Information / Links / etc?
Aug 30, 2007 2 Replies
Merv
Have you accessed the Linksys technicall support web page for the RV042 go to -> Support -> Technical support click on "hoose a Product" button enter Model number RV042 see Linksys doc "Setting-Up a VPN Tunnel on Two Linksys Routers" @
RV042 - Information / Links / etc? open original image
I'm trying to use the RV042 in a pretty reasonable way but don't seem to find much information about how it's supposed to work. Here are some things that I seem to have found but have no way to really confirm:
- For a VPN to work, the RV042 has to be in Gateway mode.
- If in Gateway mode, the static routes don't work (????)
- How do static routes affect operation when there's a VPN? with the VPN?
Does no one know? I've been asking lots of questions lately and getting mostly no responses. I don't think the questions are too off the wall.
Thanks,
Fred
go to
Yes, I have.
The issue I'm raising is getting information about how the RV042 works, not how to set it up. I can set up a VPN OK. But, there are other features that I'd like to use (like routing) that don't seem to work. And, there seems to be *no* information regarding the interrelationship between using a pair of RV042s as VPN devices and using static routes in them at the same time.
Fred
