RSM question
Jul 24, 2005 1 Replies
I recently acquired an RSM from ebay and I'm stuck on enabling IP routing on the router.
  1. I entered the following command:
Router(config)#ip routing
  1. and I get an error message:
Router(boot)(config)#ip routing ^ % Invalid input detected at '^' marker.
  1. IP command help:
Router(boot)(config)#ip ? Global IP configuration subcommands: accounting-list Select hosts for which IP accounting information is kept
accounting-threshold Sets the maximum number of accounting entries
accounting-transits Sets the maximum number of transit entries address-pool Specify default IP address pooling mechanism
alias Alias an IP address to a TCP port bootp Config BOOTP services default-gateway Specify default gateway (if not routing IP) domain-list Domain name to complete unqualified host names.
domain-lookup Enable IP Domain Name System hostname translation
domain-name Define the default domain name flow-export Specify host/port to send flow statistics gdp Router discovery mechanism gratuitous-arps Generate gratuitous ARPs for PPP/SLIP peer addresses
host Add an entry to the ip hostname table host-routing Enable host-based routing (proxy ARP and redirect)
hp-host Enable the HP proxy probe service http HTTP server configuration local Specify local options name-server Specify address of name server to use rcmd Rcmd commands security Specify system wide security information source-route Process packets with source routing header options
subnet-zero Allow 'subnet zero' subnets tacacs TACACS configuration commands tcp Global TCP parameters telnet Specify telnet options tftp tftp configuration commands
  1. I think if the routing function is on this software release it should have been displayed above, correct? Or does this mean that I have an older software version? Router print out on the SHOW VERSION command:
Copyright (c) 1986-1999 by cisco Systems, Inc. Compiled Mon 12-Apr-99 23:56 by ashah Image text-base: 0x60010900, data-base: 0x60412000
ROM: System Bootstrap, Version 11.2(17523) [mohsen 102], INTERIM SOFTWARE
Router uptime is 1 hour, 15 minutes System restarted by reload System image file is "bootflash:c5rsm-boot-mz_112-18_P.bin", booted via bootflas h
cisco RSP2 (R4700) processor with 65536K/2072K bytes of memory. R4700 processor, Implementation 33, Revision 1.0 Last reset from power-on G.703/E1 software, Version 1.0. X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
1 C5IP controller (4 Vlan).
4 Virtual Ethernet/IEEE 802.3 interface(s)
123K bytes of non-volatile configuration memory.
8192K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102
  1. Catalyst print out of SH VER command:
WS-C5000 Software, Version McpSW: 2.4(4) NmpSW: 2.4(4) Copyright (c) 1995-1997 by Cisco Systems NMP S/W compiled on Jan 23 1998, 11:54:52 MCP S/W compiled on Jan 23 1998, 12:12:25
System Bootstrap Version: 3.1(2)
Hardware Version: 2.4 Model: WS-C5000 Serial #: 008735009
Module Ports Model Serial # Hw Fw Fw1 Sw
1 2 WS-X5509 008735009 2.4 3.1(2) 3.1(1) 2.4(4)
3 1 WS-X5302 013162974 7.5 20.13 3.1(1) 11.2(18)P,
4 12 WS-X5213A 006793362 2.0 1.4 2.4(4)
Module DRAM FLASH NVRAM Used Available
1 16384K 8192K 256K 88K 168K
Your input/suggestion is greatly appreciated.
Thanks
-Marlon
I JUST solve my problem.
The Cisco IOS on the bootflash: is old, I just copied another image from a PCMCIA card and it had the latest IOS image and it worked.
