Route trafik from outside into VLAN on a ASA5500
Mar 15, 2007 2 Replies
Is this possible and if it is how can it be done?
I have a range op public IP's (80.123.123.1 - 80.123.123.64) I would like to "route" traffic from all the public IP's into its own VLAN. (VLAN1 --> VLAN64).
On everyone of the VLANs I want a virtual interface with the internal ip
192.168.1.1.
On the VLAN the servers can use the virtual interface 192.168.1.1 to get access to the Internet thug my public ip 80.123.123.1.
Is all this (or some of it) possible?
Best Regards Martin
yout VLANs will need to be on different subnets ex: 192.168.x.1
x=VLAN number
hosts in VLAN x will use 192.168.x.1 for their gateway
But will the VLAN routing work? Do the inside VLAN host's have access to the Internet (thug
80.123.123.1, my public ip gateway)
How do I deny access between VLAN's, access-lists or not existing routing?
Best Regards
L J skrev:
