RipV2 & Subnets
Jun 04, 2005 2 Replies
Hi group,
Got a something that I don't fully understand, hope someone can help me out.
I've got a VLAN with the address range (10.10.10.x) configured on a Layer 3 switch. The switch is doing all the inter-vlan routing and it works great however when I want to publish the connected networks via Rip V2 to the rest of the network I run into issues.
I'm trying to publish the connected routes out a interface on vlan 1 that has the following ip address 192.168.1.x/22. No rip packets are sent to the Vlan 1 network.
Example config snippet:
ip classless ! interface vlan 10 ip address 10.10.10.x 255.255.255.0 ! interface vlan 1 ip address 192.168.1.x 255.255.255.252 ! router rip Version 2 redistribute-connected network 192.168.1.0 !
However as soon as I change the subnet mask to 24 bits or add the following line to the Vlan 1 interface it works: ip address 192.168.1.xx 255.255.255.0 secondary
This is the part I don't understand, why is Rip being sent out a interface with a 24 bit subnet mask and not a 22. I would have thought the ip classless command would have enabled this to work.
A bit stumped on this one, hope someone can enlighten me.
Thanks in advance.
I've investigated further and from what I've read the network statement under the router rip section appears to be class based despite RIP v2 support VLSM and the ip classless command.
If so how can I make it advertise routes > Hi group,
VLSM and the "ip classless" command don't really have much to do with other (not in the sense that most people think of it anyway.
The network statement ONLY tells the router to run RIPV2 on the interfaces that fall into the (or match) the network statement. That's all there is to it.
Also, you don't need to "redistribute connected" if you're running a routing protocol that matches the interface already.
