Problems of congiguration command
Jan 03, 2006 2 Replies
Hi all,
I would like to ask what the configuration command of each router is such that the Workstation can ping the server successfully. Please check
for details. Thanks a lot for all your help!
Regards, Yiu
Skills Based Assessment Version 2 ... Directions ... The student will be responsible for configuring the four routers. ...
As this is clearly an educational situation, I would suggest that it would be appropriate for you to list as much of the configurations as you were able to come up with, and to pose *specific* questions about the parts you are not sure about.
If we were to just give you the answer, you would not learn as much as if you were to show us your existing work and we were to comment on that.
Dear Roberson,
Actually, I have configured some commands. Do you know how can I redistribute from the OSPF area 0 such that the RIP can be communicate with OSPF? Thanks!
The following shows some of the commands:
config t hostname ISP1A ! ip subnet-zero ! interface FastEthernet0/0 ip address 200.200.100.1 255.255.255.0 no shutdown speed auto ! interface Serial0/0 bandwidth 1544 ip address 200.200.2.1 255.255.255.0 clockrate 56000 no shutdown ! interface Serial0/1 bandwidth 54000 ip address 200.200.1.1 255.255.255.0 clockrate 56000 no shutdown ! router bgp 100 no synchronization bgp log-neighbor-changes network 200.200.100.0 neighbor 200.200.2.2 remote-as 200 no auto-summary ! ip classless no ip http server ! end !
config t hostname SanJose3 ! ip subnet-zero ! interface FastEthernet0/0 ip address 192.168.1.1 255.255.255.0 no shutdown speed auto ! interface Serial0/0 bandwidth 1544 ip address 200.200.2.2 255.255.255.0 no shutdown ! interface Serial0/1 bandwidth 54000 ip address 200.200.1.2 255.255.255.0 no shutdown ! router ospf 1 log-adjacency-changes network 192.168.1.0 0.0.0.255 area 0 ! router bgp 200 no synchronization bgp log-neighbor-changes network 192.168.1.0 neighbor 200.200.2.1 remote-as 100 no auto-summary ! ip classless no ip http server ! end !
config t hostname Singapore ! ip subnet-zero ! interface FastEthernet0/0 ip address 192.168.1.2 255.255.255.0 no shutdown speed auto ! router ospf 1 network 192.168.1.0 0.0.0.255 area 0 ! interface Serial0/0 no ip address shutdown ! interface Serial0/1 no ip address shutdown ! ip classless no ip http server ! end !
Walter Roberson =E5=AF=AB=E9=81=93=EF=BC=9A
