Can an ASA 5520 NATed with down stream Network IP Addresses?
Jul 26, 2007 4 Replies
CK
It looks good, but you must be having same route in internal switch and router as well.
Hello there,
Here is propose network Diagram:
Internet (ISP) | Cisco Router (207.78.3.1) 207.78.3.X block | Cisco 2960 Switch
ASA 5520 (Outside 209.78.3.2) inside 192.168.1.1
| 192.168.1.X
Cisco 2960 Switch
| 192.168.1.X Cisco Router 192.168.1.2
| 192.168.2.X
Cisco Router
| 10.10.10.X
on ASA 5520 Config, Can I static NAT 207.78,3.X with 10.10.10.X ?
nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) 207.78.3.34 10.10.10.34 netmask
255.255.255.255 0 0 route outside 0.0.0.0 0.0.0.0 207.78.3.1 1 route inside 10.10.10.0 255.255.255.0 192.168.1.2 1
I usually don't enable routing in switch, will it be OK? Can anyone double confirm this NAT settings?
thanks so much.
Go for it,
The ASA doesn't care if the inside address you want to NAT is directly connected or x hops away .
