redundat ipsec tunnels with nat
Oct 03, 2005 3 Replies
Jump to replies (3)
redundat ipsec tunnels with nat open original image
Hello, I have several remote cisco routers and one pix. There are crypto map between all the routers routers. the access-list of the crypto maps between the routers permit access to the subnet of each remote routers. something like this: access-list ip permit 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0 is it possible to setup routing so if the connection between x.x.2.x and x.x.1.x is faster going through x.x.3.x the packtes would be send through a x.x.3.x instead of directly. do i need 2 routers in each site to do this? I am think that may be if i add a router behind nat in each location using bgp this could be done. are there any examples out there for this? or some kind of redundant ipsec tunnels? thanks.
You have an interesting challenge. If by "faster" you mean higher bandwidth or lower delay, then you have a fighting change using routing protocols to make the decision. If by "faster" you mean the loading on the link is slowing it down so use an alternate, you won't get what you want with a routing protocol (at least not safely, although you could try playing with the K factors in EIGRP) and you would have to look at a load balancing appliance.
There should be multiple examples of routing through NAT using GRE tunnels on
. It is also possible to route through NAT without using GRE tunnels, see the "Reduandant Firewalls" white paper on my web site. The white paper on redundant IPsec VPNs there should also be useful, but its examples do not deal with NAT.
Good luck and have fun!
thanks for the reply, I am not really experience with GRE tunnels. May be you can answer a simple question. If I have a mesh of 10 routers, how many tunnel interfaces do i need in each router? I tried setting up BGP to avoid using the tunnel but i dont think it worked because i was unable to ping the inside address of the other routers from any router running nat. I got IOS 11.x on most of my routers and only one running
12.x. Any suggestions.
In article , wrote: :I am not really experience with GRE tunnels. May :be you can answer a simple question. If I have a mesh of 10 routers, :how many tunnel interfaces do i need in each router?
9 if you want a classic "Full Mesh".
If you are looking at a best-case scenario in which you assume that all the links work fine all the time, and you want all the hosts to be able to exchange data with each other, then you can use a star topology (1 tunnel on N-1 of the routers, N-1 tunnels on 1 of the routers). Alternately, you can use a ring topology (a forward link and a backward link on each router.)
If you are assuming that some of the links might fail sometimes, then you need to define the degree of failure that you are trying to protect against. Are you trying to protect against any one router failing? Against any two? Are you trying to minimize routing costs dynamically, with the possibility that up to M routers might fail?
:I tried setting up :BGP to avoid using the tunnel but i dont think it worked because i was :unable to ping the inside address of the other routers from any router :running nat. I got IOS 11.x on most of my routers and only one running :12.x. Any suggestions.
Well, -I- would suggest upgrading to IOS 12.3(something) or
12.4, and using the new Dynamic Mesh VPN feature. On the other hand, I do have the advantage that the argument "It's costing more in terms of my salary to keep going with the old equipment than it would cost to upgrade the equipment" does work (eventually.)
