acl questiobn
Apr 08, 2005 3 Replies
Jump to replies (3)
Hello everybody,
Does anybody know the benefit of using two acls when creating a site to site vpn one for disabling nat and then one for the crypto map. Or is it just a matter of preference Example
access-list remote_site permit ip 10.1.1.0 mask 255.255.255.0
192.168.1.0 255.255.255.0
access-list nonat permit ip 10.1.1.0 mask 255.255.255.0 192.168.1.0
255.255.255.0
nat (inside) 0 access-list nonat
crypto map remote 10 match address remote_site
I started out by having one acl like this
nat (inside) 0 access-list remote_site
Thanks
In article , jspr wrote: :Does anybody know the benefit of using two acls when creating a site to :site vpn one for disabling nat and then one for the crypto map.
We can deduce from the commands you show us that you are talking about the PIX; it is better if you state the product and software version explicitly as different products and different versions work slightly differently.
: Or is :it just a matter of preference Example
:access-list remote_site permit ip 10.1.1.0 mask 255.255.255.0 192.168.1.0
255.255.255.0
:access-list nonat permit ip 10.1.1.0 mask 255.255.255.0 192.168.1.0
255.255.255.0
:nat (inside) 0 access-list nonat
PIX only supports a single nat 0 access-list . If you have multiple crypto-maps, you have to merge all the nat exemptions together into one list, but you want the crypto maps to be seperate.
You also cannot use the same ACL for nat 0 access-list or for crypto map match-address as you are using for an access-group : that's because anything used as an access-group has internal updates as needed to implement the Adaptive Security Algorithm.
Thus, even in cases where you only have one crypto map entry, it is a good idea to get into the habit of using distinct ACLs, so as to avoid accidental reuse in the future.
If i recall correctly, there are also some bugs in some releases if you use the same ACL for nat 0 access-list as for crypto map even with only a single crypto map. I am not certain of this; I believe I found the entry using the bug navigator, but it didn't matter to me as I use distinct ACLs and it was for a software version I didn't happen to be using.
Well you will face the issue if you have both site to site and remote access (vpn clients). For further details you can go through this link:
