redirect web request to internal machine
May 04, 2006 1 Replies
Good day Everyone,
I have a cisco 2821 router and I am trying to figure out how to rediect a external web request to an internal machine sitting on vlan2.
I want to have people request a site at IP 204.67.26.123 and that request needs to be redirected to a box sitting on vlan2 at ip
192.168.0.10.
Any suggections would be great due to I have not found an answer yet.
thank you
ip nat inside source static tcp 1.2.3.4 80 5.6.7.8 80
Where 1.2.3.4 is your inside IP and 5.6.7.8 is your outside IP. You can also use the interface option if the outside IP happens to correspond to the IP of your web server. You can also use this to twist your ports.
J
