Radius authentication
Jul 25, 2007 1 Replies
We would like to use MS IAS as a RADIUS server for a centralized router management.
We were able to make it work perfectly in PAP mode but as this exposes passwords we would like to use MS CHAP.
When we just switch to MS CHAP (on the router and IAS) the authentication fails with AUTH_FAILURE. As there is no messages in Active Directory logs we conclude that the real authentication has never happened and the request has been rejected by IAS itself.
Has anyone been able to make it work with MS CHAP? Do we need to activate reverse password encryption in Windows to make it work?
Any advice will be appreciated
ha scritto nel messaggio news: snipped-for-privacy@19g2000hsx.googlegroups.com...
Check your IAS and NAS configuration. Reverisble password encryption is only necessary if you want to use "chap". Use MS CHAP version 2 if possible.
Regards, Gabriele
