Question about NAT (maybe need to use policy NAT)?
Jun 30, 2008 2 Replies
PacketU
I'm not sure what you mean by " All outgoing connections from anything on 192.168.1.0/24 is presented to the outside on xx.xx.xx.209." Your config will route all traffic to xx.xx.xx.209, but will be presented as xx.xx.xx.11-xx.xx.xx.222 then PAT'd xx.xx.xx.210. So based on the…
This is what I was thinking of doing:
Router: interface Ethernet0 ip address xx.xx.xx.209 255.255.255.240
interface Dialer0 ip address negotiated (receives WAN static)
Firewall:
interface vlan2 nameif outside security-level 0 ip address xx.xx.xx.210 255.255.255.240
interface vlan1 nameif inside ip address 192.168.1.1 255.255.255.0 security-level 100
global (outside) 1 interface global (outside) 2 xx.xx.xx.11-xx.xx.xx.222 netmask 255.255.255.240 nat (inside) 1 0 0
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.209 1 (can this go in the outside interface definition?) access-group outside_access_in in interface outside
access-list outside_access_in extended permit tcp any host
192.168.1.10 eq 25
static (inside,outside) xx.xx.xx.211 192.168.1.10 netmask
255.255.255.240
What I want to achieve with this is the following:
- All outgoing connections from anything on 192.168.1.0/24 is presented to the outside on xx.xx.xx.209.
- I have some server on 192.168.1.10 which I want presenting to the outside world on xx.xx.xx.211.
- I want people to connect to the IP address xx.xx.xx.211 on port 25 and they will be connected to this server.
Will this do it?
The other way I was looking at it was this:
global (outside) 1 interface global (outside) 2 xx.xx.xx.211 255.255.255.240 nat (inside) 1 0 0 nat (inside) 2 access-list mail_server
access-list mail_server extended permit tcp any host
192.168.1.10 eq 25
I also have some IP addresses with no inbound connections, but I need to ensure that they present on the outside using a specific IP address.
Any help would be gratefully received.
Thanks. Andrew.
Your config will route all traffic to xx.xx.xx.209, but will be presented as xx.xx.xx.11-xx.xx.xx.222 then PAT'd xx.xx.xx.210. So based on the Static the first 212 host will get a 1 to 1 nat then port level pat after that.
On the access list, you will want to specify the public ip as the destination. It is applied before the NAT changes to the private address. The second example may have unintended consequences.
I would use my recommendations and modify the first config. Also, the second config shows 211 as the start of the NAT range where the first one shows 11.
Oops, that should have been xx.xx.xx.210. I.e, the firewall outside interface.
Ok. I want to get rid of the NAT, so that we just have the PAT for xx.xx.xx.210 for anything going outside other than a few IP addresses, which will be natted to specific public IP addresses.
Ok, that makes a bit more sense. If I change:
to:
Then have this:
Will this work?
If so, will the following NAT commands be sufficient:
211 is the correct number - my bad again.
Thanks. Andrew.
