question about eigrp
Feb 20, 2006 7 Replies
Jump to replies (7)
question about eigrp open original image
hi all...me..agian!
I just noticed on my core wan router that eigrp is configured like the following:
router eigrp 1 redistribute connected redistribute static network 0.0.0.0 default-metric 256 1000 255 128 1500 no auto-summary
I have never used EIGRP, and it seems a little weird that it is needed for the inside of my network. When I do a "show ip route" two of the routes that show up are by EIGRP as follows:
D [90/28416] via , 7w0d, FastEthernet0/1
I am slightly confused as EIGRP shows up nowhere else in my lan or wan. could this be left from an old config? everything else on my network is done by static addresses.
Issue the "show ip eigrp neighbors" command on your core wan router to see who the EIGRP neighbor is that this router is learning routes from. That your routing table had an entry prefixed with a "D" indicates that there is certainly a EIGRP neighbor that is advertising routes to this router.
Cisco da Gama
ok, so here is the deal. I have a 4507 as my core switching, and one of the vlan interfaces is a neighbor to the core router. when i get a config from the 4507 it has the following:
router eigrp 1 passive-interface Vlan1 passive-interface Vlan8 passive-interface Vlan250 passive-interface Loopback100 network network network no auto-summary no eigrp log-neighbor-changes
When I issue the same show command on the 4507, it replies back with the only neighbor being the lan int of the core router.
why is this needed? Can i not use static routes as the rest of the network is using?
OK so the mystery of where the EIGRP routes were coming from is solved.
You could certainly use a static route instead of using EIGRP here and make it work if that is what you wanted to do. However note that generally speaking using static routes alone instead of dynamic routing protocols in production networks is usually not a good idea. Your question now is one regarding good design for your network and it is hard to answer that question without knowing the network much better.
Cisco da Gama
We have a very small network in the grand scheme of things. From what I can tell, eigrp is only used within the lan here and not out to our wan, so i am still slightly confused as to why we even need a routing protocol. this is probably only for the routing between vlans i would guess?
think my post got lost...trying again, sorry if this reposts.
We have a small network in scheme of things. looks like the eigrp is doing the intervlan routing is my assumption. i could also just use ip route statements on both the router and switch correct?
i inherited this network and am just trying to make sense of it all....guess we always try to get away from things we dont know! suppose i will just dive into eigrp so it makes more sense.
but i could achive the same thing with something like the following correct?
switch ip route
router ip route
I guess I am just looking for an understandind as i inherited this network. i have never used eigrp and we always try to get away from what we dont know yet! lol
EIGRP is a very simple protocol to implement and it functions quite well
Using static routs as a substitue for a dynmaic protocol is NOT a good plan.
In fact it is usually one of the surest ways to end up creting routing loops...
