Qos / TOS Confguration
Oct 05, 2005 3 Replies
Jump to replies (3)
Hi guys and girls!
I wish to prioritise VOIP traffic generated from our internal network and directed out our ADSL 256/512Kb line.
I got a shock last night when I applied the following QoS config to our company router. ALL the interfaces went "administratively down" when I applied the policy to the interface!! (using the service-policy command on interface Dialer2)
Would someone mind suggesting what fatal error I am making?! ;-)
Note that when VOIP traffic is not queued, I wish to utilise the full capacity of the ADSL line, rather than have 56Kb of bandwidth reserved purely for VOIP.
Your comments are much appreciated. See config below.
Best wishes Paul
class-map match-all voip-internal description internally generated voip traffic match access-group name tos-voip-internal
policy-map voip-outgoing class voip-internal priority 56
ip access-list extended tos-voip-internal permit udp 10.0.0.0 0.255.255.255 any tos 5 permit udp 10.0.0.0 0.255.255.255 any tos min-delay
interface Dialer2 description adsl_to_internet bandwidth 512 ip address negotiated ip access-group AdslInternetFacingInbound2 in ip access-group AdslInternetFacingOutbound out no ip redirects no ip unreachables no ip proxy-arp ip nat outside ip inspect AllProtocols out encapsulation ppp no ip route-cache no ip mroute-cache dialer pool 2 dialer-group 3 ntp disable no cdp enable ppp authentication pap chap callin ppp chap hostname ppp chap password 7
service-policy output voip-outgoing
Has anyone got any ideas about this, please?
Thanks Paul
Why are you using process switching 'no ip route-cache'? This is likely not doing you any good if this is your only path to the internet. It is however likely eating up router processor time. Thats my two cents anyway.
