Hi all,
Anyone know how to configure the user login on enable with radius? I configure it on the authetification mode as primary but the catalyst doesn=B4t question the user for enable login.
On the cli appears the following.
-------------------------------------------------------- (enable) sh radius RADIUS Deadtime: 0 minutes RADIUS Key: XXXXXXX RADIUS Retransmit: 2 RADIUS Timeout: 5 seconds Framed-Ip Address Transmit: Disabled
RADIUS-Server Status Auth-port Acct-port
10.109.7.36 primary 1812 1813
Login Authentication: Console Session Telnet Session Http Session
---------------- tacacs disabled disabled disabled radius enabled(primary) enabled(primary) enabled(primary) kerberos disabled disabled disabled local enabled enabled enabled attempt limit 3 3 - lockout timeout (sec) disabled disabled -
Enable Authentication: Console Session Telnet Session Http Session
---------------- tacacs disabled disabled disabled radius enabled(primary) enabled(primary) disabled kerberos disabled disabled disabled local enabled enabled enabled(primary) attempt limit 3 3 - lockout timeout (sec) disabled disabled -
Thanks in advance=20
Best Regards
