Problems with 7206 vxr trying to VLAN a Gig port to an HP 4000M Gig port over fiber
Sep 09, 2007 1 Replies
How hard is it to VLAN a Gig-e fiber connection from the router to the fiber Gig-e connection on my HP4000M. Both units have the latest IOS
Please email answer macvoip @ gmail.com
Thanks to all.
If its a simple single network connection, you just use plain ethernet and give it an ip address, and make sure it matches the vlan/network range on the HP4000M. If you are doing multiple vlans and trying to trunk (make the 7200 the l3 owner of multiple networks), you'll need to configure trunking on the gig port, create the interfaces you need, and trunk over those VLANs. Since ISL is Cisco proprietary, you will need to use dot1q trunking, which the HP supports (I looked it up).
The bottom of this link has information relating to configuring trunking on a router:
