Hello,
I'm having some problems with a link between two Cisco routers. One router is a 7603 with a 48 port FastEthernet switching module and the second is a cisco 2620. The two routers are directly connected. The
7603 is using a FastEthernet interface and the 2620 is using an Ethernet interface. Both interfaces are administratively up and link protocol up. However, the routers can not ping each other. I've tried changing the duplex but haven't had any success. I have noticed that the 2620 has a valid arp table entry for the 7603 but the 7603 has an incomplete arp table entry for the 2620.
I have tested the ports and the cables and everything is working correctly when interfaced to other routers, or if the 7603 connects to the FastEthernet port on the 2620. Is there a setting I'm missing or is this a possible bug? The IOS versions are 12.2(7r) for the 2620 and
12.1(13)E6 for the 7603.
Thanks.
