- There are other IPSEC tunnels working flawlessly. The only difference between them are that this one that is not working uses 192.168.70.0 - the rest use the 192.169.10.0 network.
The default gateway of your Pix is x.x.x.97, unless that is an HSRP address you are not going out the Pix that you have the VPN setup on, you are taking an alternate path via the load balancer. That also explains why the other side is not seeing your traffic.
Thanks for the help Brian, I ended up grabbing a Cisco tech to help out. We upgraded the PIX to 6.3(5) and used a policy based NAT to route the interesting traffic.
Report Content
ASAP.
