PIX remote client VPN not prompting for username and password
Oct 29, 2007 2 Replies
Hello. I am betting someone has an easy answer for this.
I have configured a PIX 506e to do ipsec remote client VPN.
Cisco VPN Client 4.8.00.0440 currently works. We can connect to the VPN simply based on the group name and password.
Here is the problem: at connect-time do not get prompted for a username and password. It just connects us. If the group name and password are correct that is all that is needed.
I have compared this to the other PIX's we have installed and I cannot see the difference. Can anyone help make sense of this? I have posted the config below (modified to protect the innocent...) THANKS A BUNCH
btw, I know we should have a different network assigned for the VPN users but we are being forced to assign IP addresses from the same network as the inside of the LAN so we can connect the laptop VPN users to a unix machine on the LAN (telnet access). The Unix vendor tells us that we MUST be on the same subnet or their system won't be accessible :^\\
PIX Version 6.3(5) interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password XXXXXXXXXXXXX encrypted
passwd XXXXXXXXXX encrypted
hostname punji
domain-name myco.net
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.0.10 csd
access-list vpnremote_splitTunnelAcl permit ip host csd any
access-list inside_outbound_nat0_acl permit ip host csd 192.168.0.192
255.255.255.192
access-list outside_cryptomap_dyn_40 permit ip any 192.168.0.192
255.255.255.192
access-list inbound permit icmp any any
access-list outbound permit ip 192.168.0.0 255.255.255.0 any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 1.1.1.2 255.255.255.252
ip address inside 192.168.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ipsecpool 192.168.0.210-192.168.0.230
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 192.168.0.0 255.255.255.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group inbound in interface outside
access-group outbound in interface inside
route outside 0.0.0.0 0.0.0.0 1.1.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpnremote address-pool ipsecpool
vpngroup vpnremote dns-server 2.5.2.5 2.2.2.1
vpngroup vpnremote default-domain myco.net
vpngroup vpnremote split-tunnel vpnremote_splitTunnelAcl
vpngroup vpnremote idle-time 1800
vpngroup vpnremote password ********
telnet 192.168.22.0 255.255.255.0 inside
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 5
ssh 7.17.98.13 255.255.255.255 outside
ssh 7.17.13.18 255.255.255.255 outside
ssh timeout 5
console timeout 0
dhcpd address 192.168.0.100-192.168.0.150 inside
dhcpd dns 2.3.4.5 2.2.2.1
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
username field password xxxxxxxx encrypted privilege 15
username field1 password xxxxxxxxxxxxx encrypted privilege 15
terminal width 80
Cryptochecksum:6418c999151ff8674257519e9c50ab7c
: end
snip..
I believe that you need:
crypto map YOUR_CRYPTO_MAP_NAME client authentication XXXXXX
(where XXX is e.g. Local or AAA Server Name etc). If you Google this you should find a number of responses.
Regards
Darren
MANY thanks. I can't believe I missed that one. It works now.
Best to you!
