PIX Port Forwarding
Nov 15, 2006 2 Replies
So I am trying to setup traffic so I can access my web server on the intranet via the external address. I have it setup so both are forwarding to port 8080. I am assuming it's not possible to recieve traffic back out of the same interface it is sent to. I currently am using a PIX 501, can anyone help me with my options. Thanks.
David
when you say address do you mean a url name or an actual IP address. For the actual IP address you're out of luck, but if it's the name you can use an internal DNS server to point to the internal address.
