Everything was working and all sudden, I can't brows Internet. Noticed that workstations couldn't ping the PIX and the PIX couldn't ping the workstations, but PIX can ping the world. I've looked at the config and the NAT seems to be there. I even added access-list 100 to permit any any with no luck. Please help.
PIX Version 6.3(3) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password *************** encrypted passwd ************* encrypted hostname MyHostName domain-name mydomain.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 66.192.47.114 Ans access-list 160 permit ip 192.168.60.0 255.255.255.0 10.1.0.0 255.255.0.0 access-list 161 permit ip 192.168.60.0 255.255.255.0 192.168.61.0
255.255.255.0 access-list 100 permit ip 192.168.60.0 255.255.255.0 10.1.0.0 255.255.0.0 access-list 100 permit ip 192.168.60.0 255.255.255.0 192.168.61.0
255.255.255.0 access-list 100 permit ip 192.168.60.0 255.255.255.0 192.168.70.0
255.255.255.0 access-list outside_cryptomap_40 permit ip 192.168.60.0 255.255.255.0
192.168.70.0 255.255.255.0 pager lines 24 logging monitor informational mtu outside 1500 mtu inside 1500 ip address outside 66.71.212.181 255.255.255.128 ip address inside 192.168.60.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm location 192.168.60.10 255.255.255.255 inside pdm location 76.44.56.18 255.255.255.255 outside pdm location 10.1.0.0 255.255.0.0 outside pdm location 192.168.61.0 255.255.255.0 outside pdm location 192.168.70.0 255.255.255.0 outside pdm location Ans 255.255.255.255 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 100 nat (inside) 1 0.0.0.0 0.0.0.0 0 0 conduit permit ip any any route outside 0.0.0.0 0.0.0.0 66.71.212.129 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local http server enable http 76.44.56.18 255.255.255.255 outside http 192.168.60.10 255.255.255.255 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set franklin esp-3des esp-md5-hmac crypto map myhostname 10 ipsec-isakmp crypto map myhostname 10 match address 160 crypto map myhostname 10 set peer 70.150.159.18 crypto map myhostname 10 set transform-set franklin crypto map myhostname 20 ipsec-isakmp crypto map myhostname 20 match address 161 crypto map myhostname 20 set peer 65.41.70.144 crypto map myhostname 20 set transform-set franklin crypto map myhostname 40 ipsec-isakmp crypto map myhostname 40 match address outside_cryptomap_40 crypto map myhostname 40 set peer 72.16.95.115 crypto map myhostname 40 set transform-set franklin crypto map myhostname interface outside isakmp enable outside isakmp key ******** address 76.44.56.18 netmask 255.255.255.240 isakmp key ******** address 78.122.41.115 netmask 255.255.255.255 no-xauth no-config-mode isakmp key ******** address 66.72.44.144 netmask 255.255.255.128 isakmp identity address isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 telnet Ans 255.255.255.255 outside telnet 0.0.0.0 0.0.0.0 outside telnet 0.0.0.0 0.0.0.0 inside telnet timeout 5 ssh 0.0.0.0 0.0.0.0 outside ssh timeout 30 management-access inside console timeout 0 terminal width 80 Cryptochecksum:*********************** : end
