Identity NAT/PAT, 2 interface, same major network - Walter Roberson,you there? :-)
Jul 21, 2005 2 Replies
Hello,
I'd appreciate a sanity check! :-) Here goes:
- 10.0.0.0/8 behind the INSIDE interface
- Access to vendor host (200.x.x.x address) via a DMZ interface
- Currently, identity NAT is setup as INSIDE (10.0.0.0/8) -> DMZ (10.0.0.0/8)
Requirements:
- Vendor requires endpoints accessing their host (200.x.x.x) to appear from a single subnet (10.1.1.0 /24)
- My endpoints live in the 10.1.1.0 /24 (5 hosts) subnet and 10.2.1.0 /24 (2 hosts) subnets
Could I simpy do the following?
- Remove the 10.0.0.0/8 identity NAT statement.
- Create a new identity NAT statement for 10.1.1.0/24. I still need to do identity NAT since I have other endpoints accessing other devices on that DMZ segment.
- Create a dynamic NAT (PAT) statement for the 10.2.1.0/24 subnet that points to an address in the 10.1.1.0/24 network (such as 10.1.1.10).
- The PAT address would be assigned a pool ID and to the DMZ interface.
When I've tried this, I don't seem to have any luck. I assume that the PIX is having issues with the identity NAT statement and the dynamic NAT (PAT) statements since the PAT address is in the range of the identity NAT statement?
Thanks for any input!
What best you can do is not to nat the traffic with the same subnet as inside but with some other subnet like 10.100.1.0. What you need is policy based nat:
access-list policy permit 10.1.1.0 255.255.255.0 200.0.0.0 255.0.0.0 access-list policy permit 10.2.1.0 255.255.255.0 200.0.0.0 255.0.0.0
nat (inside) 100 access-list policy global (dmz) 100 10.100.1.0 255.255.255.0
you have to specify in the acess-list applied on inside interface what particular ip's are allowed.
In this way you will not mess up with the static identity nat as well
Thanks for the info...I was wondering if that was the issue. I was also reviewing the policy NAT docs and wondering if that was the direction to take. It appears that it might be easier to simply NAT to another subnet and be done with it!
Thanks again for your response!
