ping from outside network
Sep 10, 2006 7 Replies
Jump to replies (7)
hi,
in my config of pix525(6.3) i only two access-group lines: access-group ping_acl in interface inside access-group ping_acl in interface dmz and i can still ping outside interface from puside network? why is that?
Are you saying that you are able to ping the outside interface from the inside network?
vreyesii
voytas wrote:
Showing us the access lists might help!
pinging of interfaces is controlled by the 'icmp' command, not by access-group .
hope this will clear all ur doubts
regard, l
Walter Robers> >
ok, so the beginning.
  1. i ping from outside network my pix 525 (outside interface).
  1. my ACL :
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max
4096) alert-interval 300 access-list ping_acl; 1 elements access-list ping_acl line 1 permit icmp any any (hitcnt=15789) access-list acl_out; 2 elements access-list acl_out line 1 permit icmp any any (hitcnt=17) access-list acl_out line 2 permit tcp any host IP_my_www_server eq www (hitcnt=4)
  1. the site you showed is not available.
tc
dabance napisal(a):
As Walter mentioned earlier, ICMP traffic bound for the PIX is not controlled by the normal access list.
There is a seperate ICMP access list:-
James
voytas wrote:
yeah, you aare right: command icmp
next time i two times ask google :)
thx
James napisal(a):
