Pix and vlan allowing traffic
Mar 22, 2006 2 Replies
Hello,
Is it possible to allow traffic from workstations located on vlan10 to fileserver (samba) located on vlan20? VLAN20 is on lower security interface.
Thank you.
In article , ntst wrote: [PIX 506E]
Yes. If you do not have an access-group applied to vlan10 then that traffic would be permitted by default. If you do have an access-group, then allow it in the named access-list .
Return traffic is also of concern. SMB can be over TCP or over NETBIOS (UDP). If you happen to be using the NETBIOS version
-and- if the server sends asynchronous packets to the clients or the server might delay a response for over 2 minutes [e.g., waiting until a file becomes unlocked] then the UDP session might time out. To deal with that you would have to either raise the UDP timeout or else permit the UDP traffic in an access-group applied to the vlan20 interface.
