can't giet a PIX 515 to forward TCP traffic
May 23, 2005 7 Replies
Jump to replies (7)
can't giet a PIX 515 to forward TCP traffic open original image
All,
Last Friday I posted a simple configuration file for a PIX 515 and noted I couldn't get tcp traffic to cross the firewall. It was pointed out I had a faulty access-list. I was pretty sure there was an additional problem beyond that, but I obviously I wanted to correct the access-list problem. Having done that, I done some more testing and still have the original problem. Here is the posting, with the access-list now added.
I hate to be the whiner, but I haven't been able to get traffic any traffic of any kind to cross between the inside and outside interfaces of my PIX 515. From inside the PIX and can ping out to hosts beyond both interfaces. And from hosts on either side, and can ping the respective interface. But I can't get tcp, or any other traffic to across the firewall. I've included the entire configuration, which from what I can tell, is totally vanilla and straight from the Cisco website tutorials. I've been fighting this for two days, so I'm sort of losing my religion on this.
Any suggestions are much appreciated.
PIX Version 6.3(4)
interface ethernet0 auto interface ethernet1 auto
nameif ethernet0 outside security0 nameif ethernet1 inside security100
hostname pixfirewall
domain-name xxxxxx.xxx
! the standard fixup protocols fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69
names pager lines 24
mtu outside 1500 mtu inside 1500
ip address outside xxx.xxx.50.14 255.255.255.0 ip address inside xxx.xxx.65.193 255.255.255.224 !! a small subnet
ip audit info action alarm ip audit attack action alarm
pdm history enable
arp timeout 14400
! not using NAT nat (inside) 0 0.0.0.0 0.0.0.0 0 0 ! I've also attempted a static route here, but to no avail
!default route route outside 0.0.0.0 0.0.0.0 xxx.xxx.50.4 1
! use the default timeouts timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 !! the newsgroup editor wraps this line timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute
! again, the defaults aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local
! allow icmp for some short term debugging access-list ping_ok permit icmp any any access-list ping_ok permit ip any any !! ** added this line access-group ping_ok in interface inside
! the pdm/web interface http server enable http 192.168.1.0 255.255.255.0 inside
no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps
floodguard enable
telnet timeout 5 ssh timeout 5 console timeout 0
terminal width 80
Like I said, this seems totally vanilla to me.
Thanks in advance for any help.
B Squared ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "We've all heard that a million monkeys banging on a million typewriters will eventually reproduce the entire works of Shakespeare. Now, thanks to the Internet, we know this is not true." --Professor Robert Silensky of California University
If memory servers you need to define static(s) if you want to allow traffic to flow from a low security interface to a high security interface.
In article , wrote: :I haven't been able to get traffic :any traffic of any kind to cross between the inside and outside :interfaces of my PIX 515. From inside the PIX and can ping out to :hosts beyond both interfaces. And from hosts on either side, and :can ping the respective interface. But I can't get tcp, or any :other traffic to across the firewall.
What have you tried for that purpose?
Since you have nat turned off, in order to get traffic back, your network would have to support proxy arp, or else your routers would have to be configured to route the inside address range to the PIX outside IP.
Have you tried 'debug packet' against the outside interface? Have you tried using 'capture' to see what's getting there and what isn't?
Even if you are NATless, you still have to make a "static" command to punch a conduit through.
You are still doing NAT, you are just NATing to the same address 8-).
The PIX essentially rebuilds the connection, even if it keeps the original address.
is a good reference. Look at "Disabling NAT."
nat (inside) are the pool of internal addresses you want to punch through. You need to list the internal addresses you want to let out, there. Then , add an access-list to bypass the actual address translation part of NAT.
In your example, I think:
Should be
nat (inside) 0 x.x.65.192 255.255.255.224
access-list 105 permit ip x.x.65.192 255.255.255.224 any nat (inside) 0 access-list 103
Which should disable NAT for that network.
B;
Couple of things:
I noticed you're using nat 0 for inside. This means you are attempting to use the inside network addresses on the outside, with no translation. From the http statements, it appears you're using the 192.168.1.0 network on the inside. Is this really what you are attempting to do?
If not, you might want to use nat 1 (or other nat id) and perform nat or pat translation to the outside network. To complete this, you would need a global statement ... which would bring the inside nat (id) to the outside network using either nat or pat.
I think this is a red herring. The two http statements:
enable the web interface on the PIX (establish it as an http server) and create an address to point the browser to. However, its worth removing them until I get the problem fixed. Or at least that's my understanding. I'm going to test all the suggestions tomorrow.
B Squared
In article , Phillip Remaker wrote: :Even if you are NATless, you still have to make a "static" command to punch :a conduit through.
Only if you want to be able to initiate connections from outside to inside.
If I read the OP's posting correctly, the OP is apparently not getting traffic in either direction.
In article , wrote: :I think this is a red herring. The two http statements:
: >>http server enable : >>http 192.168.1.0 255.255.255.0 inside
:enable the web interface on the PIX (establish it as an http server) and :create an address to point the browser to.
Not quite, or at least not as written. That statement allows inside addresses in 192.168.1/24 to use pdm.
The user's inside addresses are in a different subnet and there is no 'route' statement pointing 192.168.1 towards the inside, so effectively the user will not be able to use pdm until this is adjusted. However, this won't affect any other traffic.
