PIX 525 firewall and MySQL problem
Aug 01, 2005 0 Replies
Hi all,
Our network services group just installed a new Cisco PIX 525 firewall (software version 7.0.1) at one of our mirror sites. This system is working well, except in one case that I find baffling. All connections and protocols are working well except for MySQL throught the VPN back to our office. If we try to do activity like this:
select * from table;
over the VPN connection, the speed of that transaction becomes horribly slow to the point of failure. Our standard system is a RedHat Enterprise Linux machine running MySQL 3.23.58 which has run without a problem prior to the installation of the PIX firewall. We've tried installing MySQL on a Windows and Solaris machine and they exhibit the same problem. It seems to be related to the small packet size used by MySQL for the above select statement transaction. Table export/file imports in MySQL seem to work at a normal speed, it's only the small packets generated by the select statement that seem to be a problem.
Does anyone have any ideas/suggestions I might recommend in order to address this problem?
Thanks, Doug Farrell
