PIX with three interface and one public IP
Nov 11, 2005 3 Replies
Jump to replies (3)
hi, i've a problem with this scenario:
pix515e, three interface: inside, outside, dmz only one public IP: pppoe i need (but not have:-)
- 2 static ports from outside to dmz (10.0.0.10; port 25, 80)
- 1 static port from outside to inside (192.168.1.10; port 443) the 2 ports to dmz work fine; the 1 port to inside doesn't work :-( any idea? Is it possible? Thanks in advance...
Christian Ditters
; ; parts of the config: ;
object-group service webserver tcp port-object eq www port-object eq https port-object eq smtp object-group service dmz2inside1 tcp port-object eq smtp object-group service dmz2inside2 udp port-object eq domain
access-list ACLOUTSIDE permit tcp any interface outside object-group webserver access-list ACLDMZ permit tcp any host 192.168.1.10 object-group dmz2inside1 access-list ACLDMZ permit udp any host 192.168.1.10 object-group dmz2inside2
ip address outside pppoe setroute ip address inside 192.168.13.2 255.255.255.0 ip address dmz 10.0.0.1 255.255.255.0
global (outside) 10 interface global (dmz) 10 interface nat (inside) 10 0.0.0.0 0.0.0.0 0 0 nat (dmz) 10 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface https 192.168.1.10 https netmask
255.255.255.255 0 0 static (dmz,outside) tcp interface smtp 10.0.0.10 smtp netmask
255.255.255.255 0 0 static (dmz,outside) tcp interface www 10.0.0.10 www netmask 255.255.255.255
0 0 static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0 0 0
access-group ACLOUTSIDE in interface outside access-group ACLDMZ in interface dmz
In article , Christian Ditters wrote: :hi, i've a problem with this scenario:
:pix515e, three interface: inside, outside, dmz :only one public IP: pppoe :i need (but not have:-) :- 2 static ports from outside to dmz (10.0.0.10; port 25, 80) :- 1 static port from outside to inside (192.168.1.10; port 443) :the 2 ports to dmz work fine; the 1 port to inside doesn't work :-(
:ip address outside pppoe setroute :ip address inside 192.168.13.2 255.255.255.0 :ip address dmz 10.0.0.1 255.255.255.0
Your inside IP subnet is 192.168.13/24 but you are trying to contact
192.168.1/24 .
hi walter, sorry - that was a 'copy and paste'/'too many fingers on keyboard'-error... the config at this point is correct:
ip address inside 192.168.1.2 255.255.255.0
but don't work. Is there another reason? Thanks christian
"Walter Roberson" schrieb im Newsbeitrag news:dl2me7$e1l$ snipped-for-privacy@canopus.cc.umanitoba.ca...
hi, there is a wrong line in the config-extract...
wrong: ip address inside 192.168.13.2 255.255.255.0 right: ip address inside 192.168.1.2 255.255.255.0
that's not the failure :-( anybody another idea? thx christian
"Christian Ditters" schrieb im Newsbeitrag news:dl2lnk$e95$ snipped-for-privacy@online.de...
