PIX and VPN HELP
Nov 21, 2006 2 Replies
I am installed TACACS+ on a Windows Server I defined two users to test the configuration. On the PIX firewall I have a VPN configured for PPTP. I want the PIX to authenticate the user for the VPN against the TACACS+ server. I also want the PIX firewall to authenticate any connection which is made to the PIX firewall from the outside against the TACACS+ server. When I try to iniate a connection to the VPN server. I get an error, and I am not able to connect to the VPN server. Below is a copy of the PIX config.
Thanks
: Saved : PIX Version 6.3(5) interface ethernet0 100full interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password XXXXXXXXXX encrypted passwd XXXXXXXX encrypted hostname pixfirewall domain-name XXXXXX.com clock timezone EST -5 clock summer-time EDT recurring fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol pptp 1723 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list 101 permit ip 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0 access-list allow_inbound deny ip 59.124.0.0 255.252.0.0 any access-list allow_inbound deny ip host 24.71.105.183 any access-list allow_inbound deny ip host 163.27.116.133 any access-list allow_inbound deny ip host 218.189.179.82 any access-list allow_inbound deny ip host 84.60.164.161 any access-list allow_inbound deny ip host 222.128.34.89 any access-list allow_inbound deny ip host 202.64.47.108 any access-list allow_inbound deny ip host 87.162.179.31 any access-list allow_inbound deny ip host 70.255.106.164 any access-list allow_inbound permit tcp any interface outside eq smtp access-list allow_inbound permit tcp any interface outside eq pop3 access-list allow_inbound permit tcp any interface outside eq www access-list allow_inbound permit icmp any any source-quench access-list allow_inbound permit tcp any host B.X.X.236 eq www access-list allow_inbound permit tcp any host B.X.X.236 eq h323 access-list allow_inbound permit tcp any host B.X.X.236 eq 5060 access-list allow_inbound permit gre any interface outside access-list allow_inbound permit tcp any interface outside eq 3000 access-list allow_inbound permit udp any interface outside eq 49153 access-list allow_inbound permit tcp any interface outside eq 49153 access-list allow_inbound permit tcp any interface outside eq 10240 access-list allow_inbound permit tcp any interface outside eq 10241 access-list allow_inbound permit tcp any interface outside eq 10242 access-list allow_inbound permit udp any interface outside eq 10240 access-list allow_inbound permit udp any interface outside eq 10241 access-list allow_inbound permit udp any interface outside eq 10242 access-list allow_inbound permit tcp any interface outside eq 41170 access-list allow_inbound permit udp any interface outside eq 41170 access-list allow_inbound permit tcp any interface outside eq 4662 access-list allow_inbound permit tcp any interface outside eq 4000 access-list deny_outbound deny tcp any host 63.236.240.73 eq https access-list deny_outbound deny tcp any host 209.202.9.7 eq https access-list deny_outbound deny tcp any host 63.236.240.73 eq www access-list deny_outbound deny tcp any host 66.28.235.59 eq www access-list deny_outbound deny tcp any host 204.245.86.77 eq www access-list deny_outbound deny tcp any host 69.18.151.78 eq www access-list deny_outbound permit ip any any access-list do_not_nat permit ip 10.1.1.0 255.255.255.0 10.1.2.0
255.255.255.0 no pager logging on logging timestamp logging monitor debugging logging trap notifications logging queue 24 logging host inside 10.1.1.23 icmp permit any unreachable outside icmp deny any echo outside icmp deny any echo-reply outside mtu outside 1500 mtu inside 1500 ip address outside A.X.X.85 255.255.255.0 ip address inside 10.1.1.1 255.255.255.0 ip verify reverse-path interface outside ip verify reverse-path interface inside ip audit name POLICY1 attack action alarm reset ip audit name InfoPolicy info action alarm drop ip audit interface outside InfoPolicy ip audit interface outside POLICY1 ip audit info action alarm drop ip audit attack action alarm ip local pool ippool 10.1.2.1-10.1.2.254 pdm location 10.1.1.6 255.255.255.255 inside pdm location 10.1.1.2 255.255.255.255 inside pdm location 10.1.1.7 255.255.255.255 inside pdm location 10.1.1.23 255.255.255.255 inside pdm location 59.124.0.0 255.252.0.0 outside pdm location 63.236.240.73 255.255.255.255 outside pdm location 84.60.164.161 255.255.255.255 outside pdm location 163.27.116.133 255.255.255.255 outside pdm location 209.202.9.7 255.255.255.255 outside pdm location 218.189.179.82 255.255.255.255 outside pdm location 10.1.1.8 255.255.255.255 inside pdm location 10.1.1.30 255.255.255.255 inside pdm location 10.1.1.251 255.255.255.255 inside pdm location 10.1.1.252 255.255.255.255 inside pdm location 192.168.2.0 255.255.255.0 inside pdm location 192.168.10.0 255.255.255.0 inside pdm location 24.71.105.183 255.255.255.255 outside pdm location 66.28.235.59 255.255.255.255 outside pdm location 202.64.47.108 255.255.255.255 outside pdm location 216.178.32.48 255.255.255.255 outside pdm location 216.178.32.49 255.255.255.255 outside pdm location 216.178.32.50 255.255.255.255 outside pdm location 216.178.32.51 255.255.255.255 outside pdm location 222.128.34.89 255.255.255.255 outside pdm location 69.18.151.78 255.255.255.255 outside pdm location 70.255.106.164 255.255.255.255 outside pdm location 87.162.179.31 255.255.255.255 outside pdm location 204.245.86.77 255.255.255.255 outside pdm location 10.1.1.253 255.255.255.255 inside pdm location 64.61.25.171 255.255.255.255 inside pdm location 64.61.25.171 255.255.255.255 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list do_not_nat nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface pop3 10.1.1.23 pop3 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface smtp 10.1.1.23 smtp netmask
255.255.255.255 0 0 static (inside,outside) tcp interface 3000 10.1.1.23 3000 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface 1000 10.1.1.23 1000 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface 4662 10.1.1.8 4662 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface 49153 10.1.1.2 49153 netmask
255.255.255.255 0 0 static (inside,outside) udp interface 49153 10.1.1.2 49153 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface 4000 10.1.1.251 telnet netmask
255.255.255.255 0 0 static (inside,outside) tcp interface www 10.1.1.6 www netmask
255.255.255.255 0 0 static (inside,outside) B.X.X.236 10.1.1.7 netmask 255.255.255.255 0 0 access-group allow_inbound in interface outside access-group deny_outbound in interface inside route outside 0.0.0.0 0.0.0.0 A.X.X.1 1 route inside 192.168.2.0 255.255.255.0 10.1.1.30 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa-server AuthInbound protocol tacacs+ aaa-server AuthInbound max-failed-attempts 3 aaa-server AuthInbound deadtime 10 aaa-server AuthInbound (inside) host 10.1.1.23 nyc4u2me timeout 10 aaa authentication ssh console LOCAL aaa authentication include tcp/0 outside 0.0.0.0 0.0.0.0 0.0.0.0
0.0.0.0 AuthInbound aaa authorization include ftp inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound aaa accounting include tcp/0 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound http server enable http 10.1.1.0 255.255.255.0 inside snmp-server host inside 10.1.1.23 snmp-server host inside 10.1.1.252 no snmp-server location no snmp-server contact snmp-server community XXXXXXX snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set myset esp-3des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap client authentication LOCAL crypto map mymap interface outside isakmp enable outside isakmp identity address isakmp nat-traversal 20 isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup vpn3000 address-pool ippool vpngroup vpn3000 default-domain pix.com vpngroup vpn3000 split-tunnel 101 vpngroup vpn3000 idle-time 1800 vpngroup vpn3000 password ******** vpngroup vmr2 address-pool ippool vpngroup vmr2 default-domain pix.com vpngroup vmr2 split-tunnel 101 vpngroup vmr2 idle-time 1800 vpngroup vmr2 password ******** vpngroup grace address-pool ippool vpngroup grace default-domain xxxx.com vpngroup grace split-tunnel 101 vpngroup grace idle-time 1800 vpngroup grace password ******** telnet timeout 30 ssh 10.1.1.0 255.255.255.0 inside ssh 192.168.10.0 255.255.255.0 inside ssh timeout 60 console timeout 0 vpdn group 1 accept dialin pptp vpdn group 1 ppp authentication pap vpdn group 1 ppp authentication chap vpdn group 1 ppp authentication mschap vpdn group 1 ppp encryption mppe 128 vpdn group 1 client configuration address local ippool vpdn group 1 client authentication aaa AuthInbound vpdn group 1 pptp echo 60 vpdn username vmr2 password ********* vpdn username test2 password ********* vpdn enable outside username vmr2 password XXXXXXXX encrypted privilege 15 privilege show level 15 command access-group privilege clear level 15 command access-group terminal width 80 banner login Unauthorized access and use of this network/device will be prosecuted. banner motd Unauthorized access and use of this network/device will be prosecuted. Cryptochecksum:24558cdd86e7726fc9cc5e299b277a8c : end
Thanks
255.255.255.0 no pager logging on logging timestamp logging monitor debugging logging trap notifications logging queue 24 logging host inside 10.1.1.23 icmp permit any unreachable outside icmp deny any echo outside icmp deny any echo-reply outside mtu outside 1500 mtu inside 1500 ip address outside A.X.X.85 255.255.255.0 ip address inside 10.1.1.1 255.255.255.0 ip verify reverse-path interface outside ip verify reverse-path interface inside ip audit name POLICY1 attack action alarm reset ip audit name InfoPolicy info action alarm drop ip audit interface outside InfoPolicy ip audit interface outside POLICY1 ip audit info action alarm drop ip audit attack action alarm ip local pool ippool 10.1.2.1-10.1.2.254 pdm location 10.1.1.6 255.255.255.255 inside pdm location 10.1.1.2 255.255.255.255 inside pdm location 10.1.1.7 255.255.255.255 inside pdm location 10.1.1.23 255.255.255.255 inside pdm location 59.124.0.0 255.252.0.0 outside pdm location 63.236.240.73 255.255.255.255 outside pdm location 84.60.164.161 255.255.255.255 outside pdm location 163.27.116.133 255.255.255.255 outside pdm location 209.202.9.7 255.255.255.255 outside pdm location 218.189.179.82 255.255.255.255 outside pdm location 10.1.1.8 255.255.255.255 inside pdm location 10.1.1.30 255.255.255.255 inside pdm location 10.1.1.251 255.255.255.255 inside pdm location 10.1.1.252 255.255.255.255 inside pdm location 192.168.2.0 255.255.255.0 inside pdm location 192.168.10.0 255.255.255.0 inside pdm location 24.71.105.183 255.255.255.255 outside pdm location 66.28.235.59 255.255.255.255 outside pdm location 202.64.47.108 255.255.255.255 outside pdm location 216.178.32.48 255.255.255.255 outside pdm location 216.178.32.49 255.255.255.255 outside pdm location 216.178.32.50 255.255.255.255 outside pdm location 216.178.32.51 255.255.255.255 outside pdm location 222.128.34.89 255.255.255.255 outside pdm location 69.18.151.78 255.255.255.255 outside pdm location 70.255.106.164 255.255.255.255 outside pdm location 87.162.179.31 255.255.255.255 outside pdm location 204.245.86.77 255.255.255.255 outside pdm location 10.1.1.253 255.255.255.255 inside pdm location 64.61.25.171 255.255.255.255 inside pdm location 64.61.25.171 255.255.255.255 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list do_not_nat nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface pop3 10.1.1.23 pop3 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface smtp 10.1.1.23 smtp netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 3000 10.1.1.23 3000 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 1000 10.1.1.23 1000 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 4662 10.1.1.8 4662 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 49153 10.1.1.2 49153 netmask 255.255.255.255 0 0 static (inside,outside) udp interface 49153 10.1.1.2 49153 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 4000 10.1.1.251 telnet netmask 255.255.255.255 0 0 static (inside,outside) tcp interface www 10.1.1.6 www netmask 255.255.255.255 0 0 static (inside,outside) B.X.X.236 10.1.1.7 netmask 255.255.255.255 0 0 access-group allow_inbound in interface outside access-group deny_outbound in interface inside route outside 0.0.0.0 0.0.0.0 A.X.X.1 1 route inside 192.168.2.0 255.255.255.0 10.1.1.30 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa-server AuthInbound protocol tacacs+ aaa-server AuthInbound max-failed-attempts 3 aaa-server AuthInbound deadtime 10 aaa-server AuthInbound (inside) host 10.1.1.23 nyc4u2me timeout 10 aaa authentication ssh console LOCAL aaa authentication include tcp/0 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound aaa authorization include ftp inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound aaa accounting include tcp/0 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound http server enable http 10.1.1.0 255.255.255.0 inside snmp-server host inside 10.1.1.23 snmp-server host inside 10.1.1.252 no snmp-server location no snmp-server contact snmp-server community XXXXXXX snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set myset esp-3des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap client authentication LOCAL crypto map mymap interface outside isakmp enable outside isakmp identity address isakmp nat-traversal 20 isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup vpn3000 address-pool ippool vpngroup vpn3000 default-domain pix.com vpngroup vpn3000 split-tunnel 101 vpngroup vpn3000 idle-time 1800 vpngroup vpn3000 password ******** vpngroup vmr2 address-pool ippool vpngroup vmr2 default-domain pix.com vpngroup vmr2 split-tunnel 101 vpngroup vmr2 idle-time 1800 vpngroup vmr2 password ******** vpngroup grace address-pool ippool vpngroup grace default-domain xxxx.com vpngroup grace split-tunnel 101 vpngroup grace idle-time 1800 vpngroup grace password ******** telnet timeout 30 ssh 10.1.1.0 255.255.255.0 inside ssh 192.168.10.0 255.255.255.0 inside ssh timeout 60 console timeout 0 vpdn group 1 accept dialin pptp vpdn group 1 ppp authentication pap vpdn group 1 ppp authentication chap vpdn group 1 ppp authentication mschap vpdn group 1 ppp encryption mppe 128 vpdn group 1 client configuration address local ippool vpdn group 1 client authentication aaa AuthInbound vpdn group 1 pptp echo 60 vpdn username vmr2 password ********* vpdn username test2 password ********* vpdn enable outside username vmr2 password XXXXXXXXX encrypted privilege 15 privilege show level 15 command access-group privilege clear level 15 command access-group terminal width 80 banner login Unauthorized access and use of this network/device will be prosecuted. banner motd Unauthorized access and use of this network/device will be prosecuted. Cryptochecksum:24558cdd86e7726fc9cc5e299b277a8c : end
Thanks
255.255.255.0 no pager logging on logging timestamp logging monitor debugging logging trap notifications logging queue 24 logging host inside 10.1.1.23 icmp permit any unreachable outside icmp deny any echo outside icmp deny any echo-reply outside mtu outside 1500 mtu inside 1500 ip address outside A.X.X.85 255.255.255.0 ip address inside 10.1.1.1 255.255.255.0 ip verify reverse-path interface outside ip verify reverse-path interface inside ip audit name POLICY1 attack action alarm reset ip audit name InfoPolicy info action alarm drop ip audit interface outside InfoPolicy ip audit interface outside POLICY1 ip audit info action alarm drop ip audit attack action alarm ip local pool ippool 10.1.2.1-10.1.2.254 pdm location 10.1.1.6 255.255.255.255 inside pdm location 10.1.1.2 255.255.255.255 inside pdm location 10.1.1.7 255.255.255.255 inside pdm location 10.1.1.23 255.255.255.255 inside pdm location 59.124.0.0 255.252.0.0 outside pdm location 63.236.240.73 255.255.255.255 outside pdm location 84.60.164.161 255.255.255.255 outside pdm location 163.27.116.133 255.255.255.255 outside pdm location 209.202.9.7 255.255.255.255 outside pdm location 218.189.179.82 255.255.255.255 outside pdm location 10.1.1.8 255.255.255.255 inside pdm location 10.1.1.30 255.255.255.255 inside pdm location 10.1.1.251 255.255.255.255 inside pdm location 10.1.1.252 255.255.255.255 inside pdm location 192.168.2.0 255.255.255.0 inside pdm location 192.168.10.0 255.255.255.0 inside pdm location 24.71.105.183 255.255.255.255 outside pdm location 66.28.235.59 255.255.255.255 outside pdm location 202.64.47.108 255.255.255.255 outside pdm location 216.178.32.48 255.255.255.255 outside pdm location 216.178.32.49 255.255.255.255 outside pdm location 216.178.32.50 255.255.255.255 outside pdm location 216.178.32.51 255.255.255.255 outside pdm location 222.128.34.89 255.255.255.255 outside pdm location 69.18.151.78 255.255.255.255 outside pdm location 70.255.106.164 255.255.255.255 outside pdm location 87.162.179.31 255.255.255.255 outside pdm location 204.245.86.77 255.255.255.255 outside pdm location 10.1.1.253 255.255.255.255 inside pdm location 64.61.25.171 255.255.255.255 inside pdm location 64.61.25.171 255.255.255.255 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list do_not_nat nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) tcp interface pop3 10.1.1.23 pop3 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface smtp 10.1.1.23 smtp netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 3000 10.1.1.23 3000 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 1000 10.1.1.23 1000 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 4662 10.1.1.8 4662 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 49153 10.1.1.2 49153 netmask 255.255.255.255 0 0 static (inside,outside) udp interface 49153 10.1.1.2 49153 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 4000 10.1.1.251 telnet netmask 255.255.255.255 0 0 static (inside,outside) tcp interface www 10.1.1.6 www netmask 255.255.255.255 0 0 static (inside,outside) B.X.X.236 10.1.1.7 netmask 255.255.255.255 0 0 access-group allow_inbound in interface outside access-group deny_outbound in interface inside route outside 0.0.0.0 0.0.0.0 A.X.X.1 1 route inside 192.168.2.0 255.255.255.0 10.1.1.30 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local aaa-server AuthInbound protocol tacacs+ aaa-server AuthInbound max-failed-attempts 3 aaa-server AuthInbound deadtime 10 aaa-server AuthInbound (inside) host 10.1.1.23 nyc4u2me timeout 10 aaa authentication ssh console LOCAL aaa authentication include tcp/0 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound aaa authorization include ftp inside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound aaa accounting include tcp/0 outside 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 AuthInbound http server enable http 10.1.1.0 255.255.255.0 inside snmp-server host inside 10.1.1.23 snmp-server host inside 10.1.1.252 no snmp-server location no snmp-server contact snmp-server community XXXXXXX snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp crypto ipsec transform-set myset esp-3des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap client authentication LOCAL crypto map mymap interface outside isakmp enable outside isakmp identity address isakmp nat-traversal 20 isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup vpn3000 address-pool ippool vpngroup vpn3000 default-domain pix.com vpngroup vpn3000 split-tunnel 101 vpngroup vpn3000 idle-time 1800 vpngroup vpn3000 password ******** vpngroup vmr2 address-pool ippool vpngroup vmr2 default-domain pix.com vpngroup vmr2 split-tunnel 101 vpngroup vmr2 idle-time 1800 vpngroup vmr2 password ******** vpngroup grace address-pool ippool vpngroup grace default-domain xxxx.com vpngroup grace split-tunnel 101 vpngroup grace idle-time 1800 vpngroup grace password ******** telnet timeout 30 ssh 10.1.1.0 255.255.255.0 inside ssh 192.168.10.0 255.255.255.0 inside ssh timeout 60 console timeout 0 vpdn group 1 accept dialin pptp vpdn group 1 ppp authentication pap vpdn group 1 ppp authentication chap vpdn group 1 ppp authentication mschap vpdn group 1 ppp encryption mppe 128 vpdn group 1 client configuration address local ippool vpdn group 1 client authentication aaa AuthInbound vpdn group 1 pptp echo 60 vpdn username vmr2 password ********* vpdn username test2 password ********* vpdn enable outside username vmr2 password XXXXX encrypted privilege 15 privilege show level 15 command access-group privilege clear level 15 command access-group terminal width 80 banner login Unauthorized access and use of this network/device will be prosecuted. banner motd Unauthorized access and use of this network/device will be prosecuted. Cryptochecksum:24558cdd86e7726fc9cc5e299b277a8c : end
