Cisco 501 (6.3(5)) with VPN Client Does Not Pass Traffic
Sep 27, 2008 1 Replies
I have tried various configurations from Cisco and, most recently, plagiarized from something posted here by Buck Rogers, and still I cannot reach my home office LAN from the remote machine. The VPN software connects, but nothing seems to go through it. Can someone spot the nature of my stupidity? Thank you folks for reading this.
PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password ***** encrypted passwd ***** encrypted hostname ***** domain-name ***** fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list 100 permit ip 10.168.123.0 255.255.255.0 any access-list 101 permit ip 10.168.124.0 255.255.255.0 any access-list 101 permit ip 10.168.123.0 255.255.255.0 10.1.2.0 255.255.255.0 pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside x.x.x.141 255.255.255.248 ip address inside 10.168.123.189 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool ippool 10.1.2.1-10.1.2.254 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 101 route outside 0.0.0.0 0.0.0.0 x.x.x.142 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap interface outside isakmp enable outside isakmp identity address isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup vpn3000 address-pool ippool vpngroup vpn3000 default-domain ***** vpngroup vpn3000 split-tunnel 101 vpngroup vpn3000 idle-time 1800 vpngroup vpn3000 password ******** telnet timeout 5 ssh timeout 5 console timeout 0 terminal width 80
Typical problem: IKE (UDP/500) goes through but ESP does not. VPN connection establishes but no data is passed.
Try:
isakmp nat-traversal 20
