Ping issues
Mar 24, 2005 7 Replies
Jump to replies (7)
Hello, I have a 2600 router that I have configured it to be a DHCP server. This is what I have so far.
Diagram Router e0/0 192.168.1.100 255.255.255.0 ======== Hub ======== --->========== ========== | | LAptop A Laptop B 192.168.1.1 192.168.1.2 255.255.255.0 255.255.255.0
FYI: this is in a lab enviornment
router ip address: 192.168.1.100 Laptop A: 192.168.1.1 SM: 255.255.255.0 GW:192.168.1.100 Laptop B: 192.168.1.2 SM: 255.255.255.0 GW:192.168.1.100
Both Laptops are running windows 2000 OS.
I CAN do the following successfully
Laptop A can ping the router successfully Laptop B can ping the router successfully Laptop A can ping itself and 127.0.0.1 successcully Laptop B can ping itself and 127.0.0.1 successcully
PROBLEM is this ________________
Laptop A cannot ping Laptop B Laptop B cannot Ping Laptop A
From the router I cannot ping Laptop A or B.
Both laptops and router are on the same subnet. ipconfig on both laptop gives me IP address Subnet mask gateway.
Why cannot I ping Laptop A to B or vice versa and why is the router not able to ping either laptops.
Do I need to put a static routes ? please help
Thanks in advance for all your help
Router
Yes I do have Checkpoint firewall clients on the laptops. I did disable them. does that help?
Thanks
That is correct. it still does not work. I am not sure what else I can look. when I do show run command to see the config under memory size it does say no ip routing . Is this something that needs to be changed?
Thanks
Yes, but it has nothing to do with the ping problems you're having. When you ping from PC A to PC B, the router isn't even involved.
You need to enable IP routing so that the PCs will be able to access the Internet.
Check arp caches and traffic on each device, use a sniffer if required, double check IP addresses handed out by DHCP, replace the hub.
M
can laptop ping the router? yes? turn off firewall on laptop
