PB with cisco cable
Jan 24, 2006 1 Replies
I have an x25 machine.
When i use wic 1T with db60 - X21 cable -> OK When i use wic 2T with smart serial cable X21 cable -> interface and line protocol is down
Config on interface is the same.
If i connect my wic 2T to another cisco router, it works.
Does anyone has face this ?
Thank you for your help.
Do a "show controller" and see if you are DCE or DTE, if your DCE you will have to provide clock rate i.e
conf-int# clock rate 64
