Optimized Edge Routing
Jul 30, 2007 1 Replies
I'm looking to run Optimized Edge Routing in conjunction with BGP. Is that possible? Can I run it (with BGP) on a 2811? 2821? How much DRAM would i need for both (the BGP is Full Routes)? Does the router have to be running NAT to do OER? We prefer to keep NAT off the router.
Thanks
ha scritto nel messaggio news: snipped-for-privacy@57g2000hsv.googlegroups.com...
As far as I know (and I know very little) OER "simply" modifies the routing table by monitoring some prefixes (using SLA features); it is protocol independent and do not need NAT and it consumes memory proportionally to the prefixes it manages. It is supported even on a low-end routers so the 28xx are supported as well.
Regards, Gabriele
