OER Problems
Jan 05, 2007 0 Replies
Running c1700-sy7-mz.124-11.T.bin on a 1721 dsl (atm0.1) and T1 (se0) are the external interfaces
After bringing the dsl link down and back up, a) phone traffic, i.e. traffic coming through interface FastEthernet0.2 did not go out the remaining serial (T1) link b) oer was left in an enabled but inactive state until I did
See details below config.
Current configuration : 2779 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname dsl-oer.template ! boot-start-marker boot-end-marker ! no logging console enable password 7 101B1B13161C19021E ! no aaa new-model mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ! ! no ip dhcp use vrf connected ! ip dhcp pool 2 network 10.30.2.0 255.255.255.0 default-router 10.30.2.1 dns-server x.x.128.2 ! ip dhcp pool 10 network 10.30.10.0 255.255.255.0 dns-server x.x.128.2 default-router 10.30.10.1 ! ! ip cef multilink bundle-name authenticated ! key chain key1 key 1 key-string 7 104C060B0112005A ! oer master max-range-utilization percent 50 keepalive 1 logging ! border 10.0.0.1 key-chain key1 interface Serial0 external interface FastEthernet0.2 internal interface FastEthernet0.1 internal interface ATM0.1 external ! learn throughput periodic-interval 1 monitor-period 2 prefixes 200 aggregation-type prefix-length 32 ! oer border local Loopback0 master 10.0.0.1 key-chain key1 ! ! class-map match-all voice match precedence 5 ! ! policy-map qoso class voice priority percent 75 ! ! ! ! interface Loopback0 ip address 10.0.0.1 255.255.255.0 ! interface ATM0 no ip address no atm ilmi-keepalive bundle enable ! dsl operating-mode auto ! interface ATM0.1 point-to-point ip address x.x.132.70 255.255.255.252 ip nat outside ip virtual-reassembly no snmp trap link-status atm route-bridged ip pvc 0/35 ! ! interface FastEthernet0 no ip address ip virtual-reassembly speed auto ! interface FastEthernet0.1 encapsulation dot1Q 1 native ip address 10.30.2.1 255.255.255.0 ip nat inside ip virtual-reassembly ! interface FastEthernet0.2 encapsulation dot1Q 2 ip address 10.30.10.1 255.255.255.0 ip nat inside ip virtual-reassembly ip policy route-map voice-dsl ! interface Serial0 ip address x.x.132.122 255.255.255.252 ip nat outside ip virtual-reassembly ! ip route 0.0.0.0 0.0.0.0 x.x.132.121 ip route 0.0.0.0 0.0.0.0 x.x.132.69 no ip http server ! ip nat inside source route-map dslnat interface ATM0.1 overload ip nat inside source route-map t1nat interface Serial0 overload ! ! access-list 1 permit 10.10.10.0 0.0.0.255 access-list 2 permit x.x.132.121 access-list 10 permit x.x.132.69 access-list 102 permit ip 10.30.2.0 0.0.0.255 any access-list 110 permit ip 10.30.10.0 0.0.0.255 any ! route-map dslnat permit 10 match ip next-hop 10 ! route-map voice-dsl permit 10 match ip address 110 set ip next-hop x.x.132.69 ! route-map t1nat permit 10 match ip next-hop 2 ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4 password 7 09195C030A0E1C1B19 login transport input telnet ! end
..... after reconnecting dsl (atm) line
*Mar 8 03:24:14.018: %LINK-3-UPDOWN: Interface ATM0, changed state to up
Mar 8 03:24:15.018: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
OER state: ENABLED and INACTIVE ...
after oer master shut, no shut
dsl-oer.template(config-oer-mc)#shut dsl-oer.template(config-oer-mc)#
*Mar 8 03:28:32.070: OER MC PROCESS: Component (0) state change (1)
Mar 8 03:28:32.086: OER MC PROCESS: Component (1) state change (1)
*Mar 8 03:28:32.086: OER MC PROCESS: Component (2) state change (1)
Mar 8 03:28:32.086: OER MC PROCESS: Component (3) state change (1)
*Mar 8 03:28:32.086: OER MC PROCESS: Component (4) state change (1)
Mar 8 03:28:32.086: OER MC PROCESS: Component (5) state change (1)
*Mar 8 03:28:32.086: %OER_MC-5-NOTICE: BR 10.0.0.1 DOWN
Mar 8 03:28:32.090: %OER_MC-5-NOTICE: BR 10.0.0.1 IF AT0.1 Unverified
*Mar 8 03:28:32.090: %OER_MC-5-NOTICE: BR 10.0.0.1 IF Fa0.1 Unverified
Mar 8 03:28:32.090: %OER_MC-5-NOTICE: BR 10.0.0.1 IF Fa0.2 Unverified
*Mar 8 03:28:32.090: %OER_MC-5-NOTICE: BR 10.0.0.1 IF Se0 Unverified
Mar 8 03:28:32.090: %OER_MC-5-NOTICE: Uncontrol prefixes, Clear exit, BR 10.0.0.1 i/f AT0.1
*Mar 8 03:28:32.094: %OER_MC-5-NOTICE: Uncontrol prefixes, Clear exit, BR 10.0.0.1 i/f Se0
*Mar 8 03:28:32.130: OER MC PROCESS: Component (6) state change (1)
Mar 8 03:28:32.130: OER MC PROCESS: Main msg type 24, ptr 82F3AFEC, value 0
*Mar 8 03:28:32.130: %OER_MC-5-NOTICE: Uncontrol prefixes, Exit down, BR 10.0.0.1 i/f Se0
*Mar 8 03:28:32.130: OER MC PROCESS: Main msg type 0, ptr 0, value 0
Mar 8 03:28:32.130: %OER_MC-5-NOTICE: System Disabled dsl-oer.template(config-oer-mc)#no shut dsl-oer.template(config-oer-mc)#
*Mar 8 03:28:37.438: OER MC PROCESS: Component (0) state change (3)
Mar 8 03:28:37.442: OER MC PROCESS: Component (1) state change (3)
*Mar 8 03:28:37.442: OER MC PROCESS: Component (2) state change (3)
Mar 8 03:28:37.442: OER MC PROCESS: Component (3) state change (3)
*Mar 8 03:28:37.442: OER MC PROCESS: Component (4) state change (3)
Mar 8 03:28:37.442: OER MC PROCESS: Component (5) state change (3)
*Mar 8 03:28:37.442: OER MC PROCESS: Component (6) state change (3)
Mar 8 03:28:37.446: %OER_MC-5-NOTICE: System enabled
*Mar 8 03:28:37.450: OER MC PROCESS: Component (0) state change (4)
Mar 8 03:28:37.462: OER MC PROCESS: Component (1) state change (4)
*Mar 8 03:28:37.466: OER MC PROCESS: Component (2) state change (4)
Mar 8 03:28:37.466: OER MC PROCESS: Component (3) state change (4)
*Mar 8 03:28:37.466: OER MC PROCESS: Component (4) state change (4)
Mar 8 03:28:37.466: OER MC PROCESS: Component (5) state change (4)
*Mar 8 03:28:37.466: OER MC PROCESS: Component (6) state change (4) dsl-oer.template(config-oer-mc)#end dsl-oer.template#sh oer
Mar 8 03:28:41.346: %SYS-5-CONFIG_I: Configured from console by vty0 (10.30.2.24)
*Mar 8 03:28:42.386: %OER_MC-5-NOTICE: BR 10.0.0.1 UPmaster OER state: ENABLED and ACTIVE
