VPN between Cisco 837 and cisco 837 with IP static and ip dinamic
Dec 14, 2005 4 Replies
Jump to replies (4)
I have two routers cisco 837 (Router A), cisco 837 (RouterB). In the router A I have one ADSL without an static ip public and the router B with Static public.
The router B is no conected to ADSL I pass the ip public with a Router Cisco 7204 with and line popint to point.
the error, in the ipsec, I have to the conexion the router A to the router B is:
Mar 1 01:02:38.031: CryptoEngine0: validate proposal request
*Mar 1 01:02:38.031: IPSEC(validate_transform_proposal): invalid local address xx.xx.xx.xx
Mar 1 01:02:38.031: ISAKMP (0:1): IPSec policy invalidated proposal
*Mar 1 01:02:38.031: ISAKMP (0:1): phase 2 SA policy not acceptable!
The configuration of the routers is
Router A
Current configuration : 2826 bytes ! version 12.2 no service pad service timestamps debug datetime msec localtime service timestamps log datetime msec localtime service password-encryption ! hostname RTP0987 ! memory-size iomem 5 logging buffered 32768 debugging ! ip subnet-zero no ip source-route no ip bootp server ip audit notify log ip audit po max-events 100 ! crypto isakmp policy 1 hash md5 authentication pre-share crypto isakmp key cisco123 address ip_public_router B ! ! crypto ipsec transform-set rtpset esp-des esp-md5-hmac ! crypto map rtp 1 ipsec-isakmp set peer ip_public router B set transform-set rtpset match address 115 ! ! ! ! interface Ethernet0 ip address 10.19.87.201 255.255.255.0 ip nat inside no cdp enable standby 1 ip 10.19.87.2 standby 1 priority 110 standby 1 preempt standby 1 track ATM0 hold-queue 100 out ! interface ATM0 no ip address no ip redirects no ip proxy-arp load-interval 30 no atm ilmi-keepalive bundle-enable dsl operating-mode ansi-dmt dsl power-cutback 0 hold-queue 224 in ! interface ATM0.1 point-to-point ip address ip_public ip nat outside pvc 0/33 vbr-nrt 320 320 1 inarp 1 no ilmi manage oam-pvc manage encapsulation aal5snap ! crypto map rtp ! ip nat inside source route-map nonat interface ATM0.1 overload ip nat inside source static tcp 10.19.87.201 23 interface ATM0.1 23 ip classless ip route 0.0.0.0 0.0.0.0 ATM0.1 no ip http server ! ! access-list 115 permit ip 10.19.87.0 0.0.0.255 192.168.201.0 0.0.0.255 access-list 115 deny ip 10.19.87.0 0.0.0.255 any access-list 120 deny ip 10.19.87.0 0.0.0.255 192.168.201.0 0.0.0.255 access-list 120 permit ip 10.19.87.0 0.0.0.255 any dialer-list 1 protocol ip permit no cdp run route-map nonat permit 10 match ip address 120 !
ROUTER B
! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname VPN_CISCO837 ! ! no aaa new-model ip subnet-zero ! ip audit notify log ip audit po max-events 100 ip ssh break-string no ftp-server write-enable ! ! ! crypto isakmp policy 1 hash md5 authentication pre-share crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0 ! ! crypto ipsec transform-set rtpset esp-des esp-md5-hmac ! crypto dynamic-map rtpmap 10 set transform-set rtpset match address 115 ! ! crypto map rtptrans 10 ipsec-isakmp dynamic rtpmap ! crypto map rtpmap local-address Loopback0 ! ! ! ! interface Loopback0 ip address ip_publica ip nat inside ! interface Ethernet0 ip address 192.168.201.8 255.255.255.0 no ip redirects ip nat outside ip route-cache same-interface ip policy route-map nat crypto map rtptrans hold-queue 100 out ! interface ATM0 no ip address shutdown no atm ilmi-keepalive dsl operating-mode auto dsl power-cutback 0 ! ip nat inside source route-map nonat interface Loopback0 overload ip classless ip route 0.0.0.0 0.0.0.0 192.168.201.2 ip route 10.200.0.0 255.255.0.0 192.168.201.1 ip route ip_publica 255.255.255.255 192.168.201.2 -> I pass the ip public to the another router no ip http server no ip http secure-server ! access-list 115 permit ip 192.168.201.0 0.0.0.255 10.19.87.0 0.0.0.255 access-list 115 deny ip 192.168.201.0 0.0.0.255 any access-list 120 deny ip 192.168.201.0 0.0.0.255 10.19.87.0 0.0.0.255 access-list 120 permit ip 192.168.201.0 0.0.0.255 any dialer-list 1 protocol ip permit arp 192.168.201.1 0102.0304.0511 ARPA route-map nonat permit 10 match ip address 120 ! route-map nat permit 10 match ip address 115 set interface Loopback0 !
Only works with two ip_public static if I put in the router B
crypto map rtpset local-address Loopback0 crypto map rtpset 20 ipsec-isakmp set peer ip_public router A set transform-set rtpset match address 115
Works, but I need that works with a dinamyc ip in the router A too work if the router B is conected to One ADSL but is not my case In the router B I use the same inteface to ipsec and the LAN
Any body can help me
Thank you
Try to use the same ACL 115 (only the first statement no both).
Alex
Which router the A or the B
Do you say?
Yes try to use that one both on A and B
Alex.
