Novice needs help
May 24, 2006 0 Replies
Can someone please explain what these router commands mean? Thanks for your help. ps: my comments are preceded by ### Using 1165 out of 29688 bytes ! version 12.0 service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname Corp-WAN ! enable secret 5 $1$Hfy0$HVtYn6SGr01RgJHPW33ZG. enable password 7 025701431B030C355946061400 ! ###???? ip subnet-zero ### DNS ip name-server 141.155.0.68 ! ! ! ! interface FastEthernet0/0 ip address 192.168.11.253 255.255.255.0 no ip directed-broadcast ip nat inside ! interface Serial0/0 ip address 192.168.254.1 255.255.255.0 no ip directed-broadcast shutdown ! interface FastEthernet0/1 ip address 192.168.5.2 255.255.255.0 no ip directed-broadcast ip nat outside !
###??? ip nat inside source list 2 interface FastEthernet0/1 overload ###map 192.168.11.63 to 192.168.5.63 and so on ip nat inside source static 192.168.11.63 192.168.5.63 ip nat inside source static 192.168.11.13 192.168.5.13 ip nat inside source static 192.168.11.61 192.168.5.61 ip nat inside source static 192.168.11.58 192.168.5.58 ###????? ip classless ### send all outside traffic to 192.168.5.1 ip route 0.0.0.0 0.0.0.0 192.168.5.1 ###???? no ip http server ! ###???? access-list 2 permit 192.168.11.0 0.0.0.255 ! line con 0 password 7 0055161E145E08121A2943430C login transport input none line aux 0 line vty 0 4 password 7 0055161E145E08121A2943430C login ! ###??? no scheduler allocate end
