Need help with Cisco 1605R
Mar 16, 2005 2 Replies
Hi
Ive bought a Cisco 1605R to replace my router (a cheap D-Link)
I had problem with the router and got this new one cheap.
The router is going to be connected to a cabel modem, that has dynamic IP.
The router is running with IOS version 11.2(9)P (Image file: c1600-y-mz.112.9.P)
Now that im going to setup the router, I might as well update the IOS, but where do I get the file from?
Can someone help me with configuring it?
Ive just completet CCNA, so I know the basic commands. :)
Regards Michael
That's about the same situation as i have. You probably want to do many-to-1 NAT and run a dhcp server for your LAN and DHCP client for your cable modem.
This is my 1605r config. It's using ip-plus with a 8M flash card and
24MB (8+16) ram. Image name flash:c1600-k8osy-mz.123-9b.bin. My cable modem is a Docsys (UPC - Chello Netherlands).
I'm not sure if you can find all these features in a standard IP image or in your rather old IOS version.
! version 12.3 service timestamps debug datetime localtime service timestamps log datetime localtime service password-encryption ! hostname rtr ! boot-start-marker boot-end-marker ! logging buffered 8192 debugging enable secret 5 enable password 7 ! username password no aaa new-model ip subnet-zero ! ip dhcp pool pool01 network 192.168.24.0 255.255.255.0 default-router 192.168.24.2 dns-server ! ip cef ! interface Ethernet0 ip address dhcp client-id Ethernet0 ip access-group 100 in no ip unreachables ip nat outside load-interval 30 no cdp enable ! interface Ethernet1 description local LAN shack ip address 192.168.24.2 255.255.255.0 ip nat inside load-interval 30 ! ip nat inside source list 7 interface Ethernet0 overload ! ! this is for bittorrent and winmx p2p programs used on the .26 host ip nat inside source static tcp 192.168.24.26 6699 interface Ethernet0 6699 ip nat inside source static udp 192.168.24.26 6699 interface Ethernet0 6699 ip nat inside source static tcp 192.168.24.26 6881 interface Ethernet0 6881 ip nat inside source static tcp 192.168.24.26 6882 interface Ethernet0 6882 ip nat inside source static tcp 192.168.24.26 6883 interface Ethernet0 6883 ip nat inside source static tcp 192.168.24.26 6884 interface Ethernet0 6884 ip nat inside source static tcp 192.168.24.26 6885 interface Ethernet0 6885 ip nat inside source static tcp 192.168.24.26 6886 interface Ethernet0 6886 ip nat inside source static tcp 192.168.24.26 6887 interface Ethernet0 6887 ip nat inside source static tcp 192.168.24.26 6888 interface Ethernet0 6888 ip classless no ip http server no ip http secure-server ! access-list 7 permit 192.168.24.0 0.0.0.255 access-list 100 deny tcp any any eq telnet access-list 100 permit ip any any ! snmp-server community RW snmp-server enable traps tty ! line con 0 exec-timeout 0 0 login local transport preferred all transport output all line vty 0 4 exec-timeout 0 0 password 7 login local transport preferred all transport input all transport output all ! ntp server end
Wow
Thanks..
Your the greatest.!
Regards Michael
