Need help VWIC-1MFT1-T1 - Adtran
Jun 25, 2005 1 Replies
Does anyone have an example config of interfacing the Multiflex Trunk card to an adtran atals 800 simluator. How do I setup the dial plan in the adtran.
TIA
Easiest thing to do is to call Adtran. Support is free and they are easy to deal with. If you can get them telnet access they will dial in and do it for you.
Chris Adtran Atlas 550
