Need Help: IP pckts w/IP length field value that is bigger than the real frame size
Mar 31, 2005 0 Replies
I'm experiencing the following problem with setup of my switch: I need to setup my switch the way it will drop IP packets with unmatched length and the length value in the IP header. The work around described in your IOS release documentation CSCdp58360 seems to have no effect.
- Cathalyst 3550
- IOS Ver. 12.1(19)
- Cisco Express Forwarding (CEF) switching Disabled on the input interface Is there any way to make 3550 dropping the wrong frames insteady forwarding them padded or unpadded?
