Need a VPN solution for 25 users..already own PIX 515UR
Sep 26, 2006 3 Replies
Jump to replies (3)
Need a VPN solution for 25 users..already own PIX 515UR open original image
Hello
I have a new job with a school that has a 3Mbp Internet connection with a PIX 515UR with version 7 of the IOS and an ISA server. A few teachers VPN with PPTP to ISA and I can restrict them with packet filtering to a single IP address and port number. My supervisor wants a better VPN solution that can do what we do now plus make sure that the VPN user has a virus scanner and meets other requirements. I wanted to use PIX but ISA is in the way and VPN does not work. I have two choices (1) Convert ISA from firewall mode to poxy server mode so I can use PIX VPN features. (2) Purchase another device (Cisco ASA??) and install it in parallel to the PIX. I thought of purchasing a VPN only device but then I would still need a firewall unless I could somehow use it with the existing PIX firewall without changing anything with ISA. We expect about 15 concurrent users. We do have money in the budget so if installing a new device parallel to our PIX would work then we would want to do that. Most important is that we get the best VPN features possible, even if it means changing our network configuration. All our network switches are Cisco.
Thanks for your suggestions Elizabeth Kono
Hi Elizabeth,
You may also wish to investigate the Cisco Solution Designer:
as well as the Cisco Product Advisor:
Cisco Pre-Sales Support:
Please call 1-800-745-7381 in the USA or Canada between 8:00 A.M. and
8:00 P.M. EST.
Sincerely,
If you want to be able to check what the VPN user has running on the user's own computer, then the Cisco name for that is "Network Admission Control" (NAC)
Reviewing those briefly, it appears to me that the client MAC address must reach the controlling server. I would not have expected that information to be available remotely, but a short review of some of the PIX 6 commands suggests to me that the MAC must in fact be transported as part of an IPSec connection... but if I assess correctly, because those PPTP sessions are not terminating on the PIX (and indeed -cannot- terminate on a PIX with any current 7.x release!) then you do not have access to the remote device's MAC unless you can somehow get the IAS to cooperate (and that's provided that PPTP even knows.)
You might have to go for 802.1X authentication, having the PPTP user use EAP or LEAP when authenticating to the IAS, with the IAS sending the MAC information over to a NAC device. But I suspect that until you can manage to switch over from PPTP terminating on the IAS to some other VPN scheme that a NAC appliance would not be able to impose the policy properly.
So, if you could switch the users from PPTP to IPSec you could possibly do the trick with a NAC appliance; with the PPTP still in place, you might have to use the more general "Network Admission Framework".
ObDisclaimer: on this topic, I only know what I've briefly skimmed. If you want to persue this approach, you should find someone who knows what they are doing ;-)
Hello,
SSL VPN's seem to be taking over in this category. Aventail makes a nice product but it's pricey depending on the licenses required.
