NAT with static and outside interface - question
Jul 08, 2005 0 Replies
Hi
I want to know if it is possible to using a static nat translation for a single inside device doing the translation to a single outside serial interface address. Other inside hosts nust not be translated. I don't have an extra public address - just the outside interface address. The traffic from the single inside server will use a specific TCP port.
If possible - how - is it a case of:
- configuring a static for the inside hosts to the interface or do I specify the IP address of the interface in a pool of 1 addres (the interface IP)
- is it neccesary to use the overload if I do need a pool of 1 if the other devices will be excluded from nat with an ACL
thanks
