NAT overload with some static NAT's and a block public IP's
Jun 30, 2005 2 Replies
Please review the config below :
interface GigabitEthernet0/0 ip address 192.168.1.254 255.255.255.0 ip nat inside no cdp enable ! interface ATM0/0/0 dsl equipment-type CPE dsl operating-mode GSHDSL symmetric annex B dsl linerate AUTO pvc 0/35 encapsulation aal5mux ppp dialer dialer pool-member 10 ! ! interface Dialer10 ip address 80.80.80.9 255.255.255.248 ip nat outside encapsulation ppp dialer pool 10 dialer persistent ppp authentication pap callin ppp pap sent-username user password pass ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer10 permanent ! ip nat translation timeout 300 ip nat inside source route-map RMP_DIALER10_OVERLOAD interface Dialer10 overload ip nat inside source static tcp 192.168.1.2 25 80.80.80.14 25 extendable ip nat inside source static tcp 192.168.1.2 80 80.80.80.14 80 extendable ip nat inside source static tcp 192.168.1.2 443 80.80.80.14 443 extendable ! ip access-list extended ACL_DIALER10_OVERLOAD permit ip 192.168.1.0 0.0.0.255 any ! route-map RMP_DIALER10_OVERLOAD permit 10 match ip address ACL_DIALER10_OVERLOAD match interface Dialer10 !
In this configuration any traffic to the Internet generated by the server on private IP 192.168.1.2 gets a source address 80.80.80.9 after the NAT overload (for which for some other reason's I have to use a route-map). I want this server 192.168.1.2 to be reachable on the Internet via public IP
80.80.80.14 for a few select ports, which works fine. But I want the server to use another IP address from the public range than the one assigned to the dialer interface (80.80.80.14, which i'm also using for the inbound traffic to the server). How can I accomplish this?
Ronald de Leeuw
You could try creating a new nat pool and specifying the server as the only host to use it. You'll also have to deny this server from using the Dialer interface. Something like this should work (note that I guessed at the netmask for your registred address space):
ip nat translation timeout 300 ! ! add a new pool and reference to it for the server: ! ip nat pool SERVER_POOL 80.80.80.13 80.80.80.13 netmask 255.255.255.240 ip nat inside source list SERVER_ACL pool SERVER_POOL overload ! ip nat inside source route-map RMP_DIALER10_OVERLOAD interface Dialer10 overload ip nat inside source static tcp 192.168.1.2 25 80.80.80.14 25 extendable ip nat inside source static tcp 192.168.1.2 80 80.80.80.14 80 extendable ip nat inside source static tcp 192.168.1.2 443 80.80.80.14 443 extendable ! ! add a new acl for just the server: ! ip acecss-list extended SERVER_ACL permit ip host 192.168.1.2 any ! ! deny the server from using the dialer interface pool: ! ip access-list extended ACL_DIALER10_OVERLOAD deny ip host 192.168.1.2 any permit ip 192.168.1.0 0.0.0.255 any ! route-map RMP_DIALER10_OVERLOAD permit 10 match ip address ACL_DIALER10_OVERLOAD match interface Dialer10
HTH - Good luck!
R> Please review the config below :
HTH - Good luck!
