Nat on Stick
Mar 01, 2006 0 Replies
Hi, i have a 1751 connected to the internet ( via adsl ). The router is configured with pat and i have an internal web server ( pat static ). The problem is that internal client cannot access to the internal web server with ip pubblic address. I know that this problem could be solved with "nat on stick" but to configure this feature is necessary that the pubblic ip address used for PAT must be different from the pubblic ip of the WAN . In my scenario i must configure pat with the ip address of dialer ( negotiated-ippcp ) and therefore i cannot to use this configuration. Is possibile to use other tricks to make this possibile ?
thanks
giuseppe citerna ccie#10503
