DNS, NAT and ASA5510
May 22, 2006 0 Replies
I'm setting up an ASA5510 with 1 public IP address on the outside interface. I've currently got all the internal hosts NATing out and I have several ports on the outside interface forwarding to specific hosts on the internal network. All this is working. I am currently trying to setup DNS rewrites. I have most of it working, but am having difficulties with some of it.
Here's my current setup:
Outside Interface: Assigned 200.10.10.1
Internal Interface: Assigned 10.1.0.1
Web server: Assigned 10.1.0.5
FTP server: Assigned 10.1.0.6
DNS server: Assigned 10.1.0.2 DNS A record
points to 10.1.0.5 DNS A record ftp.somedomain.com points to 10.1.0.6
The web server, ftp server and DNS server are on the internal network
I have successfully issued this command: static (outside, inside) 10.1.0.5 200.10.10.1 netmask 255.255.255.255 dns
From a client on the outside network, a DNS query for
returns 200.10.10.1 as desired.
I would like a DNS query for ftp.somedomain.com to return the same address, but when I issued this command:
static (outside, inside) 10.1.0.6 200.10.10.1 netmask 255.255.255.255 dns
I get an error stating that there is a duplicate of an existing static.
How can I get DNS rewrite to modify to different internal IP addresses to the same outside address?
