manage Cisco 7940 desk phone from desktop
May 02, 2007 2 Replies
manage Cisco 7940 desk phone from desktop open original image
Maybe this is far-fetched need. If so, please tell me.
I have Cisco IP 3940 on my office desk and extension is assigned and works fine. My laptop is connected to the Cisco phone with the ethernet cable. So the setup is
ethernet-port --> Cisco 7940 ethernet-cable my laptop
with this setup, is there any windows-based software available in the market with which I can manage the IP phone? I specifically looking for features like outbound calls, incoming calls notification, call log, integration with outlook address book etc.
I used to use shoretel in my previous company, but we don't have that here.
thanks Ashwani
The more important part rather than showing us how the cables go is what the phone system is.
A 3940? Do you mean its a 3640 running CCME? (or its previous incarnations such as ITS?)
This software sounds like its somewhat of what you want, assuming you are running CCME.
Hi Ashwani,
Cisco Softphone application allows you to control your real Cisco IP Phone. Here is a link to the section, which describes how to do this:
Also, with this solution you can be distant from the phone, and use a Bluetooth headset (you will need a Bluetooth adapter for the phone).
Good luck,
Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress)
------ Headset Adapters for Cisco IP Phones
