Local LAN access - not working
Feb 28, 2006 3 Replies
Jump to replies (3)
I'm having trouble getting a VPN connection that uses a Sprint Broadband PC card to be able to see network shares. I have a PIX506e with split tunneling enabled. I'm using client version 3.6.4 on the laptop in question. I have checked the option to "Enable local lan access" in the client. The client is set to start prior to windows login and I have the dialer program for the Sprint Connection set to launch from the VPN client. Everything connect and works fine from that aspect, but after the connection is made, I can't access any network shares. I can ping the servers I'm trying to reach by IP or name and do get responses. The first 2 always time out, but afterwards, I get 200-300 ms pings consistantly. Is this just a latency issue or do I need to modify the acl in some way? I don't see any routes in the route table for the local network when connected through the vpn.
Any insight would be appreciated..
Matt
Suggest you try a more recent client to see if you issue still persists.
The latest Cisco client version is 4.8
But some people have reported big problems with 4.6 and 4.8 and needed to go back further than that.
