ISAKMP KEY ******** issue
May 30, 2005 4 Replies
Jump to replies (4)
On the pix, and Im using preshared keys ok. I type in isakmp key test address 10.10.10.10 netmask 255.255.255.255 when i do a sh run under that line all i get is isakmp key ******** address 10.10.10.10 netmask
255.255.255.255 Just wondering how I go about viewing the preshared key Every time I do a show run it gets replaced by ******** all the time Any ideas would be great
Thanks
Yes, PIX doesn't show the pre-shared keys or unencrypted passwords. Set up a TFTP server and use command
write net
Then you can look the configuration file on the TFTP server and check the passwords.
If you have entered it yourself, why do you need to see it?
I have a feeling that if you "write net" and save the config to a TFTP server you can see the proper keys.
I am looking at this for debugging purposes. Would be handy if you could see it in the running config I would think
yes if you save it to a TFTP server it work no probs.
G'Day everyone, I figured out a way actually, I don't know if its the correct way or not but it works for me:
sh tech-support detail | >
