Cisco PIX to PIX VPN issue
Mar 19, 2008 1 Replies
I have a client with two locations that I'm setting up a a point-to- point VPN. The tunnel was up and idle earlier today, it's nonexistant now, and I'm out of ideas.. At no time was I able to ping across the PIX's.
Pix #1 also has a VPN config for remote clients that works fine.
Here's pertinent info from each configs:
PIX #1 name 192.168.1.0 CRVSH access-list nonat permit ip 10.0.0.0 255.255.255.0 172.16.10.0
255.255.255.0 access-list nonat permit ip 10.0.0.0 255.255.255.0 CRVSH 255.255.255.0 access-list 101 permit ip 10.0.0.0 255.255.255.0 CRVSH 255.255.255.0 ip address outside 66.x.x.247 255.255.255.0 ip address inside 10.0.0.254 255.255.255.0 ip local pool ipsec-pool 172.16.10.1-172.16.10.50 global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outside 0.0.0.0 0.0.0.0 66.x.x.1 1 sysopt connection permit-ipsec no sysopt route dnat auth-prompt prompt "You are entering a secure site" crypto ipsec transform-set myset esp-des esp-md5-hmac crypto ipsec transform-set crvshvpnts esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map crvshvpn 1 ipsec-isakmp crypto map crvshvpn 1 match address 101 crypto map crvshvpn 1 set peer 69.x.x.74 crypto map crvshvpn 1 set transform-set crvshvpnts crypto map crvshvpn interface outside isakmp enable outside isakmp key ******** address 69.x.x.74 netmask 255.255.255.255 isakmp identity address isakmp policy 1 authentication pre-share isakmp policy 1 encryption des isakmp policy 1 hash md5 isakmp policy 1 group 1 isakmp policy 1 lifetime 1000 isakmp policy 8 authentication rsa-sig isakmp policy 8 encryption des isakmp policy 8 hash sha isakmp policy 8 group 1 isakmp policy 8 lifetime 86400 isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 2 isakmp policy 10 lifetime 86400 vpngroup xrrv address-pool ipsec-pool vpngroup xrrv dns-server x.x.x.x x.x.x.x vpngroup xrrv wins-server 10.0.0.2 vpngroup xrrv default-domain x vpngroup xrrv idle-time 1800 vpngroup xrrv password ********
PIX #2 names name 10.0.0.0 CRVRFD access-list 101 permit ip 192.168.1.0 255.255.255.0 CRVRFD
255.255.255.0 access-list nonat permit ip 192.168.1.0 255.255.255.0 CRVRFD
255.255.255.0 ip address outside 69.x.x.74 255.255.255.248 ip address inside 192.168.1.1 255.255.255.0 global (outside) 1 interface nat (inside) 0 access-list nonat nat (inside) 1 0.0.0.0 0.0.0.0 0 0 access-group 110 in interface outside route outside 0.0.0.0 0.0.0.0 69.x.x.73 1 sysopt connection permit-ipsec crypto ipsec transform-set crvshvpnts esp-des esp-md5-hmac crypto map crvshvpn 1 ipsec-isakmp crypto map crvshvpn 1 match address 101 crypto map crvshvpn 1 set peer 66.x.x.247 crypto map crvshvpn 1 set transform-set crvshvpnts crypto map crvshvpn interface outside isakmp enable outside isakmp key ******** address 66.x.x.247 netmask 255.255.255.255 isakmp policy 1 authentication pre-share isakmp policy 1 encryption des isakmp policy 1 hash md5 isakmp policy 1 group 1 isakmp policy 1 lifetime 1000
According to my directions from the Cisco site, it looks like I have everything I need. The tunnel was up when I did a show crypto isakmp sa earlier today, but now it's not showing in the list. My brain is fried, and I need a little help. Can someone help shed some light on what I've done wrong?
Michelle
As you say that it was working..just try changing the pre-shared key on both the peers. You could check what the the status of the tunnel and try doing a debug
show crypto isakmp sa debug crypto isakmp debug crypto ipsec
paste the output over here, if it still has issues.
thanks
