Hi all, Can anybody tell me, Is the RIP and BGP are used in the same Router/Switch? Pls help me out as early as possible.
Thanks in advance..
BR,
-stuart-
You can run any combination of routing protocols on a router or switch, and even redistribute router between the protocols.
Read the full replyHi all, Can anybody tell me, Is the RIP and BGP are used in the same Router/Switch? Pls help me out as early as possible.
Thanks in advance..
BR,
-stuart-
Philip, Thanks for ur prompt response. So do u say like, we can implement any routing protocols combination to the Routers/Switches. how abt the processing ? how it will update the routing table? is it have any priority regarding the routing protocols? If I set multiple Routing protocols, from which protocol it will processing the Route?
Pls, excuse me if I asked silly questions. But its all the doubts I have..
//Stuart
It depends on the administrative distance (AD). The route with the lowest AD will be picked, each routing protocol has it's own AD.
Static route* 1
Enhanced Interior Gateway Routing Protocol (EIGRP) summary route 5
External Border Gateway Protocol (BGP) 20
Internal EIGRP 90
IGRP 100
OSPF 110
Intermediate System-to-Intermediate System (IS-IS) 115
Routing Information Protocol (RIP) 120
Exterior Gateway Protocol (EGP) 140
On Demand Routing (ODR) 160
External EIGRP 170
Internal BGP 200
Unknown** 255
