need help w/ PAT overloading on PIX 501
Mar 11, 2005 3 Replies
Jump to replies (3)
Still trying to have users on an outside LAN (10.1.1.x) browse or use telnet services via PAT to an inside LAN (192.168.1.x). So a user browsing 'http://10.1.1.5:50000' would reach the web server on port 80 at 192.168.1.50.
Here's the current rules. I've put in comments as the way I understand these rules to work.
--- PIC 501 V6.2(2) --- # this is my outside LAN from which I'm trying to access # specific host from using PAT overloading ip address outside 10.1.1.5 255.255.255.0 # and this is the inside LAN ip address inside 192.168.1.1 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
global (outside) 1 interface
# I want users on the outside to browse host 192.168.1.5 # using a URI like http://10.1.1.5:50000static (inside,outside) tcp interface 50000 192.168.1.50 www netmask
255.255.255.255 0 0 # ... and the same for telnet static (inside,outside) tcp interface 50001 192.168.1.50 telnet netmask
255.255.255.255 0 0
# added this as told so that outside host 10.1.1.30 # could talk to the PIX 501, not really clear to me # why though. access-list out2in permit tcp host 10.1.1.30 host 10.1.1.5 eq 50000
access-group out2in in interface outside
--- Just more info ---
# show static outside 10.1.1.0 255.255.255.0 10.1.1.5 1 CONNECT static inside 192.168.1.0 255.255.255.0 192.168.1.1 1 CONNECT static
While trying to add either of these ... access-list out2in permit tcp any interface outside eq 50000 results in "ERROR: invalid IP address interface"
access-list out2in permit tcp any outside eq 50000 results in "ERROR: invalid IP address outside"
Am I missing anything? Any help much appreciated.
In article , snipped-for-privacy@gmail.com wrote: :Still trying to have users on an outside LAN (10.1.1.x) browse or use :telnet services via PAT to an inside LAN (192.168.1.x). So a user :browsing 'http://10.1.1.5:50000' would reach the web server on port 80 :at 192.168.1.50.
Did you put in an http fixup for the port? If not then when the server returns URLs with embedded IP or port information, the PIX is going to send it out untouched.
Ok, so I added ...
fixup protocol http 50000
and there's already a 'fixup protocol http 80' in the list.
The one thing I'm noticing is that each time I try to browse 'http://10.1.1.5:50000', or do the same with telnet on 50001, the hitcount increments one like it's receiving the request for that access-list item.
#show access-list access-list out2in permit tcp host 10.1.1.11 host 10.1.1.5 eq 50000 (hitcnt=1)
Any more ideas?
