ike phase 1 lifetime, asa with netscreen
Jun 09, 2009 1 Replies
Hi all
Ipsec, L2L, in configuration I set 8h, on both side
IKE Peer: x.y.z.w Type : L2L Role : initiator Rekey : no State : MM_ACTIVE Encrypt : 3des Hash : SHA Auth : preshared Lifetime: 28800 Lifetime Remaining: 24897
but in logs, keys are changing in every 6 hours:
Jun 6 11:17:46 masterasa Jun 06 2009 11:17:46: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w Freeing previously allocated memory for authorization-dn-attributes
Jun 6 17:17:46 masterasa Jun 06 2009 17:17:46: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w, Freeing previously allocated memory for authorization-dn-attributes
Jun 6 23:17:46 masterasa Jun 06 2009 23:17:46: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w , Freeing previously allocated memory for authorization-dn-attributes
Jun 7 05:17:47 masterasa Jun 07 2009 05:17:47: %ASA-4-713903: Group = x.y.z.w, IP = x.y.z.w, Freeing previously allocated memory for authorization-dn-attributes
Someone knows what's reason of that ?
thanks Bart
I am not an IPSEC expert however I understand that new keys are generated before the old ones expire so that valid keys are always available.
Perhaps this is what you are observing?
Maybe I am too far towards the pragmatic side however I would not be concerned by this unless other symptoms were present:-)
