if CEF is working ? [ was T1 x 2]
Apr 21, 2005 2 Replies
Thanks to your advice, I am able to config the two routers 1760, each with 2 WIC-1DSU-T1-V2, to connect with each other thru two T1 lines.
From a host on this site I can ping hosts on the other site, no matter
which T1 line is up.
I setup CEF share-loading per-packet. Which command can help me check if the packets are really sent round-robin on these two lines ?
Thanks,
DT
Well, throwing a bunch of traffic down the link, and checking on the per-packet and bandwidth usage on all the interfaces in use probably would be a good start.
Thanks. I just tried by using traceroute. Running tracroute multiple times, I can see the alternative SE to be chosen.
DT
